First post, by quailstorm
I did not have manual, but found out this motherboard is the same as one Amptron one. So to change FSB one needs to unplug JP11 A jumper.
Source: https://web.archive.org/web/20080313102206/ht … html/m754+.html
Hello
I own a PC Chips M754LMR+ V3 board, drivers can be found here: https://web.archive.org/web/20091221003 ... 82&LanID=0
Sadly I don't have the latest bios nor the manual.
The BIOS of the computer, also the last downloadable from webarchive seems to contain the CPU I just installed today. It is a Celeron 1.1GHz which runs at 100MHz FSB and 11x multiplier. (SL5XR)
http://www.cpu-world.com/sspec/SL/SL5XR.html
My issue is that the CPU runs at 733MHz, because I am unable to change the FSB from 66MHz to 100MHz. The option to do so is simply locked, I don't see anything else related to this in the BIOS. There are no FSB jumpers either. Only the multiplier is changeable, but the CPU is locked at 11x so I can only downclock.
I am puzzled, what may be the issue?
