Checked... but cannot figure where does pin 22 of the KBC go... The pin of the socket on the back side of the board is a dead end... that means it should be on the top of the board, but also cannot see it go anywhere...
Now... or is the path hidden under the socket, or is the PCB a multilayer board, which would make this near to impossible to fix (but this is rather improbable for a pcb of that era and price).
So I guess I will have to try and take out the socket... 🙁 That was something I wanted really to avoid... Will try tomorrow with another KBC from another 386 motherboard (as far as I know they are all the same, and if the datasheet confirms the two chips are electrically identical then I see no reason why it wouldn't work right?).
