First post, by Synaps3
I was originally going to post this as a question, but I figured it out.
I have an old AT motherboard with a 1996 Award BIOS. I am using an IDE to CF/SD card adapter with a 64GB SD card. As expected, the BIOS only recognizes 8.4GB. I think OK, well I'll just make a second partition when windows boots to use the remaining space. This concept works, sort of.
I kept receiving the error bsod inaccessible boot device 7B. Turns out, the drive can not be partitioned as larger than 2GB exactly (2000 MB) and not even 2048 MB; that resulted in the same error.
Just posting in case anyone else wants to install an NT based OS on hardware of this era.
Systems:
BOARD | RAM | CPU | GPU
ASUS CUV4X-D | 2GB | 2 x PIII Tualatin ~1.5 GHz | Radeon HD 4650
DELL DIMENSION XPS 466V | 64MB | AMD 5x86 133MHz | Number Nine Ticket to Ride
Sergey Kiselev's Micro8088 10MHz | 640KB | Trident VGA
