First post, by Skanque
- Newbie
Hi Vogons
I have been lurking for some time, reading up on different posts regarding retrobuilds.
The vintage, I have dedicated my energy towards is Pentium III, especially the late Tualatin models.
For some time I have been using a Soltek SL-65EP+T with the following specs:
PIII Tualatin @ 1.4ghz with Thermaltake Volcano 7 cooler plus arctic silver 5 paste
SDRam 512 stick Micron CL2
120GB Seagate Barracuda ultra ata
Leaktek A400 Geforce 6800 128mb
Soundblaster Audigy EAX
VIA via6212l USB 2.0 PCI hub
The system ran flawlessly with my Soltek board... but oh boy the Soyo is one unstable ****...
The board came with bad caps (Sacon 1500uf 10v), I have replaced them with Sanyo (2200uf 10v).
According to this forum, the increased capacity should not be a problem ?
Anyway I can get xp installed on the Soyo board, and the driver cd. I can install the VIA USB hub, Geforce and Soundblaster.
I have added 2 ekstra sticks of 512mb for a total of 1,5GB system ram.
Problems:
The USB hub has been a nightmare to install, and its totally unstable. Stopping mid transfers, recognizing flashdrive and forgetting it again.
The system fatally crashes when trying to run a 3D app, rthdribl or 3d mark 2001.
Solution?
What is my next step guys?
I would love comparing results against my intel 815ep boards. I also have a Asus Tusl2-c.
But I think the 512 mb really is a limiting factor on the intel systems.
TLDR
Soyo SY-7BA133U, crashes to hard reboot, when trying to run 3d applications, the board have replaced caps.
