First post, by _ar
Hello,
I have an ESCOM Blackmax 286 mini pc motherboard which not working and I would like to fix. I found no schematic for this on the net, but I know I have at least an SMD cap and a resistor missing from around the power switch connector area. If you have a PC with this mobo and would be so kind to attach a high resolution shot of that area, that would be much appreciated.
Thanks beforehand!
_ar
