First post, by Synaps3
This is somewhat of a continuation of my thread here:
Windows 2000 inaccessible boot device 8.4GB BIOS - solution
I am having a problem with the IDE controller on MSI MS-5146 (SiS 5571 chipset) socket 7 motherboard. The problem involves random read errors from the drive after installing an OS. The only OS I can make work is DOS, but I have a feeling the problem is just less noticeable with DOS because there is so little disk IO happening. Originally, the BIOS had the 8.4GB limit problem. I was thinking of going the XT-IDE route until I discovered a 128GB BIOS patch when searching "Microstar" instead of MSI (was unaware that was their original name). The patch "worked" as in it now shows the proper drive size in the BIOS, but the problem still remains.
Here is what I have tried and what happens as a result:
1. I don't have an IDE drive less than 128GB, so I try a larger IDE drive. No matter the settings in BIOS, it hangs the system.
2. I tried an IDE to SD card adapter. The 64GB SD card is detected correctly by the BIOS.
  • I install windows 2000
    Drive shows the correct size and formats
    Copies all installation files
    After windows 2000 boot logo - BSOD (inaccessible boot device - 7B)
3. I tried to install windows 98 on SD card.
  • Boot windows 98 disk and type 'fdisk'
    Partition the drive
    Verifying drive integrity - works fine
    It asks to reboot, so reboot
    No partitions visible on reboot (it didn't do anything)
4. I tried to install windows 2000 with partition < 2GB
  • This worked, but was unstable and resulted in many BSOD over time
5. I tried an IDE to SATA converter with 64GB SSD (i do have SATA drives < 128GB, just not IDE)
  • Same problem as #2
6. I tried a PCI IDE controller (one with a VIA chip that is supposed to be bootable). It would not detect any drives.
7. I used DOS 7.1 with 4GB SD card in the IDE to SD adapter.
  • This is the only one that seems to work, but I am doubtful that it's stable.
Does anyone know why this is happening? I remember a long time ago I had a Baby AT motherboard with Pentium MMX. This was when I was pretty young and just getting into computer stuff. I remember trying to install windows on it also and having similar problems. Is this a thing that runs common among this mobo era? I can't remember much of what I tried back then, but I gave up eventually and I don't know what happened to the board.
Systems:
BOARD | RAM | CPU | GPU
ASUS CUV4X-D | 2GB | 2 x PIII Tualatin ~1.5 GHz | Radeon HD 4650
DELL DIMENSION XPS 466V | 64MB | AMD 5x86 133MHz | Number Nine Ticket to Ride
Sergey Kiselev's Micro8088 10MHz | 640KB | Trident VGA
Reply 1 of 11, by Synaps3
I just found this: http://forums.storagereview.com/index.php?/to … on-an-sis-5571/
Maybe it has to do with DMA or other IDE mode enabled in BIOS? I don't know if it is enabled or not, but I can check the BIOS in a few hours.
Systems:
Reply 2 of 11, by Synaps3
There was no DMA option in the BIOS.
OK, I managed to find an old 20GB IDE drive at the bottom of a bin (no, not outdoors 🤣).
I plugged it in and. . .
It gets farther!
It detects the drive as the right size. It allows me to partition and format it. It copies all the windows 2000 files. It reboots and loads the OS. This is farther than before. I gets all the way to the last file copy screen and reboots in the middle of the copy 😜 Tried this twice and it rebooted at slightly different points during the install.
I think the problem has been resolved, but I am still uncertain. I think this hard drive has problems of its own and that's why it's rebooting. I do think the mobo is OK, just not 100% sure.
Assuming the problem has been fixed by using an old hard drive like this, can someone recommend an IDE to SD card adapter that is known to work with older systems. It's weird because I thought I read reviews of people using mine for older systems. I am not sure what it is about the newer controllers that don't work with the board. I know when I booted with the new old 20GB drive, it said LBA Mode 4. I don't know if that is something to consider.
Maybe I should use compact flash instead. Would that be more likely compatible?
Systems:
Reply 3 of 11, by Nprod
Have you tried using something like OnTrack Disk Manager like they did in the old days?
Reply 4 of 11, by Synaps3
I have not. Since I loaded the 128GB BIOS patch and the BIOS is reading the size correctly, the detection is not the problem. There is something wrong with the IO. Would using a drive overlay also help with these problems or only with the size limit?
I just bought a compact flash adapter in hope that it will work better than the SD card. Apparently CF is PATA so it doesn't need a converter chip. Only problem is a lot of the CF cards I look at say UDMA and I know that this machine doesn't support it, so hopefully it will default back to PIO.
Systems:
Reply 5 of 11, by yawetaG
Actually, the BIOS might still be the problem. It is very well possible that the parameters are properly read with the update, but the BIOS still can't handle a drive that large...
Quick Google on disk limits https://www.tldp.org/HOWTO/Large-Disk-HOWTO-4.html
Also, check for other problems that may cause IO instability (failing power supply? faulty memory?).
Reply 6 of 11, by Synaps3
yawetaG wrote:
Actually, the BIOS might still be the problem. It is very well possible that the parameters are properly read with the update, b […]
Good to know. I'll see if I can find an 8GB SD card and try that. Everything I've tried so far has been larger (except the DOS 4GB install - which might be why that one worked) because I thought the BIOS patch would have fixed the problem. What's the point of patching if it only shows the right number.
I'll try the 8GB and report back if it works.
In addition, I ran DOS benchmarks and I ran MemTest86 for 6 hours with no problems. The problem is related to the IDE controller or BIOS.
Systems:
Reply 7 of 11, by yawetaG
It might be that it also failed to detect the correct settings with much smaller hard disks.
What happens if you run a benchmark that does read/write cycles on the hard disk?
Furthermore, check if the problem only occurs some time after booting, or is it present right at boot? If the former is the case, you're looking at something that fails after the system has heated up, e.g. a bad solder joint. Also check the capacitors on the mobo for bulging or other damage, and maybe pop open the power supply (when disconnected from the mains!) to have a look there.
Reply 8 of 11, by Synaps3
It is present right at boot and it seems pretty predictable where the boot process fails.
The 8GB SD card arrived and it has the same problem. I am still not sure I have the drive parameters correct. I've been letting the BIOS do the detection on its own and it gets the correct size, so I did not pay too much attention to the cyls, heads, etc.
Here is what the BIOS says (this is the auto detection of the 8GB SD card):
OPTIONS    SIZE   CYLS     HEAD     PRECOMP     LANDZ     SECTOR     MODE
2(Y) 7946 966 255 0 15399 63 LBA
1 7948 15400 16 65535 15399 63 NORMAL
3 7948 1925 128 65535 15399 63 LARGE
I have tested both LBA and NORMAL modes. When booting under LBA mode the BIOS reports "LBA Mode 4" and under NORMAL mode it says, "CHS Mode 4". Is this mode 4 too old to be compatible with CF or SD cards?
What I find strange is that I've heard of people using CF or SD cards on much older systems like 486s and report them working. I don't understand this.
There is also one other strange thing about this comp. It can not reboot itself. It just goes to a blank screen and then I have to turn the power off and on manually. I think this is just because I am using an ATX to AT power supply convertor.
I'm almost ready to either send this mobo back to the seller I got it from or try to sell it myself (with the above caveat). It's been consuming a lot of my time and the board I even got to replace it didn't work either - for other reasons.
It still very well might work with a normal hard drive under 8GB, but it is not worth it to me even if it does.
Systems:
Reply 9 of 11, by Synaps3
I have moved on to a new motherboard, but I just wanted to update this thread so that people can gain some insight if they are having a similar problem.
I am not 100% sure, but I believe my problem with this mobo's IDE controller was that it was not UDMA compatible and thus will probably only work with a real ancient hard drive. I have moved to the GA-5AX and the CF card works just fine. So if you're looking at using socket 7 system with a SiS chipset make sure you either use a real old HDD (less than 8GB) or MAYBE an ancient CF card that doesn't use UDMA.
Systems:
Reply 10 of 11, by dionb
I'm not so sure about that diagnosis...
It's true that the SIS 5571 only supports PIO4/DMA2, but IDE is fundamentally backwards compatible when it comes to standards. I've frequently run HDDs supporting UDMA on PIO4 chipset boards and they work - albeit at slower transfer speeds of course. So lack of UDMA support itself isn't the issue. I rather suspect that whatever beta BIOS patch you have installed that shows >128GB HDDs correctly is just plain buggy. Either that or as Yawetag suggests there might be other issues upstream of the I/O subsystem. With the GA-5AX you're using different RAM for starters, so that's still a possible cause.
Reply 11 of 11, by retardware
This is also my feeling.
For my DFI K6 board there were also offered BIOS patches, but they did not work reliably.
For this reason on my retro systems I do not bother dealing with IDE drives at all. An IDE or SATA optical drive for booting, and all HDDs on SCSI.
