First post, by Jed118
- Oldbie
I burned out my BIOS chip - it was inserted backwards when I put the board into storage ever so long ago - when I went to test some DLC chips on it, it did not post. I only noticed it because my finger touched the top of the EEPROM when I went to disconnect the power leads to the mobo: It burned me!
I tried a bunch of BIOS chips I kept from when I was a kid, and they all emitted some kind of beeps (especially the AWARD BIOS chips) when inserted. Some did nothing, but I know they work (on other AWARD boards) as I had experimented with swapping them into a 3/486 board in the not too distant past.
So, there's a chip on eBay now, same everything (my version is 2.11, but I know 2.10 will work from prior tinkering) EXCEPT it says 386SX BIOS
AFAIK the memory addressing does not happen in the BIOS.
Likelihood of it working? The board is a typical M321, I recently put 256k cache on it.
Failing that, does anyone know where I can get my hands on a replacement?
What's for sale? my eBay!
