Windows XP Help me pick a CPU
Discussion about old PC hardware.
Re: Windows XP Help me pick a CPU
Postby red_avatar » 2019-2-04 @ 07:55
It's HD 4870 you're right - I often mistype this as 4850 (my old phone number started like that) but it's a 4870 from 2009.
I opened to case to check the rest for you: the Audigy 2 is model SB0240 but with no gold contacts.
The motherboard is an ASUS P8H67-M Evo from 2011.
http://www.pcstats.com/articleimages/20 ... _fullH.jpg
All its drivers are available in XP which isn't bad for a motherboard released 5 years after Vista.
https://www.asus.com/Motherboards/P8H67 ... _Download/
In essence, this is a PC that could be used for almost all games from 2000-2010 which is ideal. Games newer than that, nearly all run on my modern rig anyway.
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
User avatar
red_avatar
Postby Tertz » 2019-2-10 @ 20:14
red_avatar
thanks for the useful info
Older mouse model which appeared to work better with older games than a newer model is still interesting to be said. I suspect there should be good working modern models or there can be software issues. The concrete information about mouses models can to help to understand the situation better.
the latest MBs with official XP drivers and PCI slots (for old sound cards) were on 77 chipset alike Asus P8Z77-V
Tertz
Postby Merovign » 2019-2-11 @ 06:13
I use an i3-2120 in a Dell Optiplex 790 USFF, so I'm all kinds of oddball and non-retro (I do have the parts to build a proper era system but this is a tiny dictionary-sized box and it works *astonishingly* well).
Merovign
Postby red_avatar » 2019-2-11 @ 14:42
Tertz wrote:red_avatar
Well I only own gaming mice - every mouse I bought in the past 7-8 years has been a gaming mouse with higher dpi. I seriously suspect that this is the cause of the problem - the mouse sending too much info to the PC for the game to handle. Maybe it's a buffer overflow? The game expecting, say, 10 coordinates per second but receiving 30 so the game ends up lagging behind because it's still processing the first 10 coordinates while it keeps getting new coordinates - some won't fit in the buffer so are lost which explains the behaviour where the mouse only moves more or less accurately if you move it sloooowly but jumps all over the place if you move it quickly.
Retro game fanatic.
User avatar
red_avatar
Previous
Return to General Old Hardware
Who is online
Users browsing this forum: kaputnik, Scandy and 6 guests
