First post, by Dracolich
Greetings, vogons. This is an edit of a previous post.
I have a HP Mini 1116NR netbook that is too old to be usable for much anymore. I have an idea to take the 16GB ssd and use it to replace an 18GB primary slave hdd in my DOS gaming rig. This is the ssd:
https://images-na.ssl-images-amazon.com/image … pUL._SX355_.jpg
Looks like the model# is SDPA1AA-016G and the chip has the numbers "20-99-00104-5" , "S846-702376" and "SDC1". I have already gotten a 1.8" zif to IDE adapter and tried in a IDE-USB enclosure on my main rig in Win7 and in Linux but it does not work.
https://www.amazon.com/SMAKN%C2%AE-ZIF-Micro- … +ce+zif+adapter
I tried with both of the included cables as well as the original cable from the laptop, but the disk is not detected. I know it says ideal for Toshiba and Hitachi but for the price it was worth a shot. Is anyone familiar with this type of ssd and know an adapter that will work? If not, I can get a 16GB CF with an IDE adapter (same as my DOS rig's primary master drive) but I was hoping to use stuff I already have. 😀
Thanks in advance for any ideas
