First post, by TheMLGladiator
I finally got a fresh install of windows xp installed and am wondering if I should install any of the "optional" updates. Is there any real benefit for these?
EDIT: Thanks for the replies! I will probably go and install the updates.
Reply 1 of 10, by dkarguth
You might as well install them, they most likely are bug fixes. I see no real reason not to unless you just don't want to wait for the install.
"And remember, this fix is only temporary, unless it works." -Red Green
Reply 2 of 10, by SirNickity
Kind of curious if there are community repos or custom roll-up packs for old Windows versions? Like, has someone made a community final service pack for Win98?
Reply 3 of 10, by kaputnik
For W98 there's one, http://www.htasoft.com/u98sesp/.
Dunno about other Windows versions. Would definitely be interested to know if there's an XP one at least.
Reply 4 of 10, by TheMLGladiator
I believe there is also one for Windows XP called Windows XP sp4 or something like that, though I have no experience with it.
Reply 5 of 10, by oeuvre
There is an unofficial XP service pack 4 but it borks updates.
Reply 6 of 10, by cyclone3d
Run far away from it.... Just use the February 2004 Microsoft update CD for Windows updating Windows 98.
http://www.vogonsdrivers.com/getfile.php?file … =873&menustate=
Then use the USB storage driver and you are set.
http://www.vogonsdrivers.com/getfile.php?file … 035&menustate=0
No need for all the crazy hacked together stuff that is flaky in the unofficial service pack.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 7 of 10, by TheMLGladiator
cyclone3d wrote:
Run far away from it.... Just use the February 2004 Microsoft update CD for Windows updating Windows 98. http://www.vogonsdriver […]
I had no idea that CD even existed. I've found plenty of useful stuff (like an iso for my sound blaster audigy), but I guess I should give vogonsdrivers a browse. 🤣
Reply 9 of 10, by kaputnik
The base system update package from U98SESP has never given me any problems that I know of at least, using it on a few systems. The feature options that adds stuff from later Windows versions etc are probably best to avoid though.
Also had no idea that official update pack existed, will try it the next time I install W98SE 😀
Reply 10 of 10, by SirNickity
Nice, I'll grab that 2004 update disc for 98. I hope somebody puts together a compilation like that for Win95 and WinME eventually. XP SP3 seems to be pretty OK as it is.
