Reply 40 of 63, by Deksor
By the way, have you made a backup of the BIOS ? I need that for my page about HP vectras ^^
alternative
Reply 41 of 63, by thepirategamerboy12
No, I haven't backed it up yet. I've tried doing so and I keep just getting an empty file.
Also, I managed to find another hard drive that works with this machine and the problem still remains...
Reply 42 of 63, by Deksor
have you tried the earliest version of uniflash possible (available here : http://www.win3x.org/win3board/viewtopic.php?f=22&t=19455) ? it managed to backup the bios of my HP vectra successfully !
How big is the new hdd ?
alternative
Reply 43 of 63, by thepirategamerboy12
Alright, I think I was able to dump the BIOS. I'll upload it soon.
The hard drive is 1.2GB, similar to the old one. By the way, I want to benchmark this drive, but Speedsys always gets stuck at "Determining Memory Type." Any ideas on that?
Reply 45 of 63, by Totos82
thepirategamerboy12 wrote:
Thank you very much!!!!!! You are the first, who uploaded this bios in the whole wide internet!!!!!! Thank you again!! You are a god!!!!!!!!!!!
Reply 46 of 63, by pentiumspeed
Replace the hard drive! The pauses is early sign of failure on early hard drive is not as sophisticated as later hard drives were.
You can use any PATA up to 40GB or so, hard drive even the computer sees it as 8GB, just go ahead and partition with your favorite OS.
Cheers, pentiumspeed
Great Northern aka Canada.
Reply 47 of 63, by thepirategamerboy12
I just said I replaced it with another one of a similar size, and it has the same issue. I doubt both drives themselves are somehow bad in the exact same way.
Reply 48 of 63, by yawetaG
...unless the problem is the hard disk controller.
If you have a controller card you could try whether your problems go away if you use that. But before that, try drive overlay software.
Reply 49 of 63, by thepirategamerboy12
I don't have a controller card on hand. What would you recommend for a 486? Also, at least with the on-board IDE, the HDD reads at about 1.7mb per second. Is that considered acceptable for a 486?
Reply 50 of 63, by Deksor
It looks allright, my vectra performs at 1.8MB/sec
However with an ISA controller it might be slower. I suspect the "VL" in the name of the computer to mean "VLB" (or it's just for the "VLSI" chipset that's inside)
alternative
Reply 51 of 63, by thepirategamerboy12
I see. Other than the already known stuck access issue, this drive seems to work fine. The only different speed-related thing I noticed compared to the old drive is that it actually takes about 2 seconds to create a directory, which I don't think I've ever seen before. Microsoft Office on Win 3.1 took ages to install (assuming because it has lots of different folders).
Reply 52 of 63, by thepirategamerboy12
Sorry that this is an old thread, but I got back to tackling the issue again. I took out the CPU and it is a DX2-66, and not a 50mhz one like the BIOS says. Hmm...
Reply 56 of 63, by sylon
thepirategamerboy12 wrote on 2019-03-10, 04:41:
Hi! Can you tell me how you backed the Vectra's bios? I tried uniflash (pci bus not found error) and nssi (made a 66kb bio file)..
Thanks!!!
Reply 57 of 63, by sylon
sylon wrote on 2021-04-14, 19:50:
Thanks!!!
Ok its worked! 😀 With an older uniflash.. 1.18..
Actually I found someone who has a VL2 with a Ga.04.06 bios, that's why i needed.
Now i have to figuredout how to flash it back to my Vectra 😀
Reply 58 of 63, by Deksor
Can you share that version with us ? I'd like to add it here 😀 http://www.win3x.org/uh19/motherboard/show/7243
alternative
Reply 59 of 63, by sylon
Deksor wrote on 2021-04-14, 20:30:
Of course! As soon as i get it! 😀
