286 Motherboard with Keyboard error/Keyboard interface error
Discussion about old PC hardware.
Postby muon » 2019-2-11 @ 10:31
Hi
I have this motherboard ACER, INC.RT-286-12/16
https://stason.org/TULARC/pc/motherboar ... 12-16.html
When I power on I get a message error: keyboard error.
While it is powering on I get a lot of "backfire" through speaker. I took a video:
https://mega.nz/#!bJ80RSTS!1cH6zC1w6iJD ... CNothta3Hw
The battery was leaked and the keyboard conector was rusty. I changed these two elements. Now the backfire is gone, but the keyboard error continues.
Any suggestions?
muon
Re: 286 Motherboard with Keyboard error/Keyboard interface error
Postby root42 » 2019-2-11 @ 10:38
Did you try simply hitting F1? Might simply be due to CMOS without valid data. Else you should trace the connections from the keyboard connector to the keyboard controller with a multimeter in continuity and see if there is some broken trace due to battery corrosion.
Soldering, retro game reviews and more on YouTube and Bonus videos
Me playing games on my 286 and on my Sega MD2 on Twitch
80386DX@25 MHz, 8 MiB RAM, Tseng ET4000 1 MiB, schlae AdLib, PC MIDI Card + SC55MkII, XT CF Lite, OSSC 1.6
User avatar
root42
Postby muon » 2019-2-11 @ 20:31
root42 wrote:Did you try simply hitting F1? Might simply be due to CMOS without valid data. Else you should trace the connections from the keyboard connector to the keyboard controller with a multimeter in continuity and see if there is some broken trace due to battery corrosion.
The board hasn't got a jumper for clearing CMOS data, but I bet It is broken trace or something like that
muon
Postby dkarguth » 2019-2-11 @ 21:17
286 boards don't normally have cmos clear jumpers. Does the keyboard really not work, or is it just a random error? Also, have you tried another keyboard? Most 286 motherboards will throw a keyboard error if they detect a key is held down during power up. I would check to see if your keyboard has a stuck key.
Also, does anyone else find it humorous that the bios asks for the user to press the F1 key on their keyboard if it detects that the keyboard isn't functioning?
"And remember, this fix is only temporary, unless it works." -Red Green
dkarguth
Postby kixs » 2019-2-11 @ 21:19
Check all the traces near the battery. At least one is broken in that area.
My Amibay: SALE | BUY - Updated on 2019-01-24
User avatar
kixs
Postby root42 » 2019-2-11 @ 21:38
dkarguth wrote:286 boards don't normally have cmos clear jumpers. Does the keyboard really not work, or is it just a random error? Also, have you tried another keyboard? Most 286 motherboards will throw a keyboard error if they detect a key is held down during power up. I would check to see if your keyboard has a stuck key.
Yes, I had this error quite a few times. And keyboard would work, simply by pressin F1.
But this error might even happen with no keyboard attached....
User avatar
root42
Postby muon » 2019-2-12 @ 09:12
First of all: thanks you at all
Second: the keyboard is OK. I use that keyboard for all my retro motherboards and it works properly - in all other motherboards - without any problems.
Pictures the "danger zone" I'll tested with polimeter
Image Image Image Image Image
How can i repare a trace? Is there any kind of pencil for restoring that?
muon
Postby root42 » 2019-2-12 @ 09:51
If you definitely found the trace that is broken, you have to run a wire across the gap. You can either remove some solder mask on either side of the gap and simply run a short jumper wire, soldering it to the exposed copper of the trace. Or you can run a long jumper wire, soldering it on the bottom of the board from the pin at the keyboard connector whose trace is broken to the pin on the SOCKET of the keyboard controller IC where this broken trace leads to.
User avatar
root42
Postby kixs » 2019-2-12 @ 10:04
Remove the battery and check the traces under it.
User avatar
kixs
Return to General Old Hardware
Who is online
Users browsing this forum: johndias, kiwa and 14 guests
