First post, by Deksor
- l33t
I've been playing with that 7600GS for a while and I hadn't had any issue with it so far
But then I wanted to refresh the thermal paste that was probably not doing its job very well due to age. So I pressed the plastic things holding the heatsink, but as they were very hard, I had to take a small pair of pliers. It worked well, but near the last one there was a couple of surface mounted capacitors ... and I ripped two of them by accident 🙁
The PCB is fine, but the card don't work anymore ...
Here are shoots from the crime scene
I have enough soldering skills to fix that, but I have no idea what values these caps had ... Does anyone know ?
