First post, by teslamaitre
Hi, i own a motherboard GIGABYTE GA-486IM with 256 Ko of DATA SDRAM Cache, here is a picture :
http://mail.lipsia.de/~enigma/neu/pics/mainboard_ga486im.jpg
Could you give me a reference of chips to mount DATA SDRAM Cache up to 512 Ko ?
Thanks.
Reply 1 of 5, by Deksor
Perhaps the same but you replace 256 by 512 in the ref ? ^^
It seems to exist
Reply 5 of 5, by teslamaitre
Yes, you're right, it's 64b x 8 and not 128b x 8.
According the user's manual, it is possible to upgrade the L2 cache from 256 Ko to 512 Ko (See the manual p.14 : http://www.motherboards.org/files/manuals/47/4im_9412.pdf ).
--> Actually, 8 chips UM61256AK-15 28 pins are installed to make 256 Ko.
--> I own 8 chips UM61512AK-15 32 pins to make 512 Ko L2 cache.
The problem is the following : on the motherboard, there are 4 supports for 28 pins chip and only 4 supports for 32 pins.
Thanks for your help.
