First post, by arteq
Hello Collegues,
I need bios bin for motherboard SNOBOL MINI 286 needed SNB-MOO8.
As far as I know it sould be AMI BIOS 3.03NP.
Or maybe you have jumper settings as well 😀
Thank you in advance.
    306.37 KiB
Some items for sale 😀
https://docs.google.com/spreadsheets/d/1YNG8R … dit?usp=sharing
Reply 4 of 9, by arteq
finally mobo got POST 😀 thanks again @BastlerMike
    508.64 KiB
    post bios
Reply 5 of 9, by root42
Nice board and great result. I spot some unpopulated RAM silk screen outlines. Is it possible to add additional sockets to get to 1MiB without having to use the SIPP sockets? Could be nice for Himem, so you get a bit more conventional memory.
YouTube and Bonus
Reply 6 of 9, by Caluser2000
Just get simm adapters and plug them into the sipp sockets to get more ram. May need to remove the dimms or set jumpers to get it working. https://sbfmdrv.blogspot.com/2016/01/using-si … s-as-sipps.html
Reply 7 of 9, by arteq
I wil ltry to solder pins to SIMM 30 module and install it in the SIPP socket
Reply 8 of 9, by Cyrix200+
Check out the link by Caluser above. It shows an alternative to that.
1982 to 2001
