First post, by user33331
Hello ( Installing a 3.5" floppy drive to an old I/0 card cable 386/486 ? )
Beginner amateur questions:
1.) What is the name of this "old-style floppy" I/0-cable with 4pcs of connectors ? ( See picture )
2.) Can I just use a regular modern floppy cable with only a 1pc connector ?
I can't get the 3.5" 1.44mb floppy to work:
- Must I set it as a *Floppy A* or *Floppy B* in BIOS ?
- Do I need drivers ?
- It says "Not ready reading drive A Abort, Retry, Fail?".
https://en.wikipedia.org/wiki/Abort,_Retry,_Fail%3F
- Which way the floppy connector goes ? ( See picture )
    94.47 KiB
Reply 1 of 3, by tayyare
This cable can only be called as "floppy cable with connectors for 5.25 drives" or "old style floppy cable" AFAIK, I can't recall any special names for it, and yes, you can use a simpler one with two 3.5 connectors only,
In any case, if the drive is designated as drive A in the BIOS, it must be connected after the twist. In the picture you attached, the place of the 3.5 drive A is correct.
There is no standart (in general) in which way to connect the connector to a 3.5 floppy drive though, but it's a simple matter of trial and error, there are only two possibilities at the end.
Hint: If the drive led is illuminated as soon as the system is powered up and stays illuminated, then the cable is incorrectly connected, try the other way around.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 3 of 3, by Jo22
I think the same as tayyare. Looks like an ordinary floppy cable from the late 80s/early 90s.
It should support two floppy drives, with either a modern or classic connector (edge connector).
If there''s a coloured cable (often red) on one side of the ribbon cable, then it is marking the side were the "1" pin of the floppy drives usually goes to.
