First post, by classicvga
Hi Everyone,
I need a bit of advise for picking the best socket 939 motherboard for my needs. Im currently running my setup on Gigabyte GA-7N400 Pro2 with Athlon XP 2500+ which is perfectly fine. But you probably know the hassle when your cpu doesn't support proper SSE2 instruction set which means I will have to upgrade both MB/CPU. The system is mostly used for retro 3D cards testing and some light gaming of course 😀
My choices are narrowed down to these models below, simply because I can find them on my local market. But since they are not at the bargain prices to say the least, I would like to know your opinion about it.
Asus A8V Deluxe
MSI K8T Neo2-FIR
Gigabyte GA-K8NS-939
What do you guys think? Does anyone have experience with these models? Which one would you pick if prices are comparable? Or are they any other options on the market? The "ultimate" MB should support Athlon 64 X2, AGP and 4GB of DDR400.
would appreciate any input on this topic, thx 😀
classicvga
