Reply 80 of 115, by mothergoose729
wrote:Yes, I have some SS7 AMD K6-3+ 450mhz builds over clocked to 550mhz. If I enable turbo button I can cut the CPU speed in half to […]
wrote:wrote:I think this 486 build is a good build because you can down clock the CPU to 386sx-25mhz for for playing old DOS games and play modern DOS games at 100 or 133mhz.
Phil done some i thing Pentium 200 zillions speeds test enable, disable caches and different clock speeds etc..
By the way K6-II+ at lowest speed without underclocking FSB - at 150 or 200 MHz and disable caches, that is comparable 386/486 system?
If I enable turbo button I can cut the CPU speed in half to 333mhz.
If I use the Setmul utility in combination I can reduce the speed to 200mhz.
But that is not low enough to play CPU critical games like "Wing commander-1"
You need a 33mhz computer for that.
That is why I like the convenience and versatility of the 486 ( 66/100/133mhz. ) computer.
I am sure you know this already, but you can set the FSB to 66mhz and use setmul to get down to that speed. I think a K6 III+ at its slowest is equivalent to a 386DX25.
