Asus VL/I-486SV2GX4 Rev. 2.0
Discussion about old PC hardware.
Re: Asus VL/I-486SV2GX4 Rev. 2.0
Postby jesolo » 2019-5-12 @ 18:36
skel2raw wrote:Do you know which cache chips I need to get in order to upgrade the board to 1MB chaceh?
Here's a link where you can download the entire manual. It gives you the cache options and configurations: https://www.philscomputerlab.com/upload ... manual.pdf
skel2raw wrote:Do you have an idea, where I can find information about how to set the pins for the LED panel of the case?
That varies between different makes of LED displays.
Your best option would be to trial and error. You can change the jumpers while it's on. Just remember there is a setting with the turbo on and turbo off.
User avatar
jesolo
Postby skel2raw » 2019-5-13 @ 11:41
Thanks. I figured out the jumpers for the LED displays. Now it shows LO and HI.
However with the cache I have not been succesfull so far. Do you know specific chip models/names?
skel2raw
Postby jesolo » 2019-5-13 @ 14:47
skel2raw wrote:However with the cache I have not been succesfull so far. Do you know specific chip models/names?
What do you currently have on the motherboard? I don't think the make would make any difference. As I recall, the motherboard manual specifies 20 nanoseconds or faster but, I would recommend 15 nanoseconds or faster. This will then allow you tighter cache and RAM timings.
Take note that the TAG Cache RAM is probably 8K now but, you will require a larger TAG cache RAM if you wish to increase your Cache above 128K (refer to the manual)
User avatar
jesolo
Postby skel2raw » 2019-5-13 @ 21:03
Ok, I just found a guy on ebay who was selling the chips I need for 1MB from another 486 mainboard. The TAG ram, can I simply use the same chip like the other 8 chips or is it anything special?
skel2raw
Postby jesolo » 2019-5-13 @ 21:21
It is the same type of memory than your other cache RAM chips but, take note that the size of the memory sometimes differs to the other cache RAM chips.
User avatar
jesolo
Postby skel2raw » 2019-5-16 @ 07:11
So I finally got a eprom programmer and burned a new chip. The computer boots up perfectly and now also shows the proper CPU speed all the time :)
Next is to get a AMD 5x86 to work with the board - just need find the proper jumper settings anywhere.
skel2raw
Previous
Return to General Old Hardware
Who is online
Users browsing this forum: Caluser2000, FAMICOMASTER, looking4awayout, MSN [Bot] and 13 guests
