Packard Bell Legend 610 PB400 Motherboard disk controller failure
Postby vga256 » 2019-5-15 @ 14:38
Hi all. I've got a PB Legend 610 486 SX-25. The NiCad battery began to leak, so I swapped it out with a NiMH battery of the same voltage and fit. The machine worked well for a few months, until it very recently began showing a "fixed disk controller failure" on boot. I've tried several different drives with the board, and all of them produce this error message regardless of the disk geometry settings in BIOS.
So I ordered a replacement board from eBay. This one arrived with battery leakage corrosion, which I cleaned up. It has *exactly the same* disk controller failure as my original board. What are the chances both boards suffer the exact same failure?
Can anyone give me some troubleshooting ideas on narrowing down what's causing the hard drive controller failure? I thought the controller is on the drive itself, not on the board?
Thanks!
BIOS error
battery corrosion (before)
vga256
Re: Packard Bell Legend 610 PB400 Motherboard disk controller failure
Postby dionb » 2019-5-15 @ 16:25
"Disk controller failure" can be as simple as incorrect CHS settings (due to loss of CMOS data) or a dead/dying HDD. What happens if you attach the same drive with the same settings to a different system?
User avatar
dionb
Postby oeuvre » 2019-5-15 @ 18:40
yeah it's likely a dead or faulty HD
HP Z420 Workstation Intel Xeon E5-1620, 32GB, AMD FirePro V7900 2GB, SSD + HD, XP/7
User avatar
oeuvre
Postby vga256 » 2019-5-15 @ 20:11
Thanks for the ideas so far. Just tested the drive (Seagate ST3120A) in my Pentium 100, and it works fine with the same CHS settings and IDE cable.
Any other ideas on figuring out the source of the controller error on my PB400 board?
vga256
Postby vga256 » 2019-5-19 @ 14:47
Update:
A few pics of the motherboard:
Top side of board
Underside of board
Battery location and corrosion
vga256
Postby oeuvre » 2019-5-19 @ 14:52
you might need to solder on a few SATA ports
User avatar
oeuvre
Postby vga256 » 2019-5-19 @ 15:04
oeuvre wrote:you might need to solder on a few SATA ports
I'll probably go with PCIe if it comes to that.
vga256
Who is online
Users browsing this forum: Cobra42898, dionb, Google [Bot], imi, keropi, mpe and 14 guests
