First post, by Rodoko
Two weeks before I decided to grab a case that had a 486 motherboard inside, the infamous PC-Chips M919 rev. 3.2
When I got the board from a friend in 2017, it did not work so I putted on a case and forget about it until this year where I installed a 486/66 and most of the components that came from my Pentium 200 and bam! it turned on, so after playing with the 486/66 a bit I decided to upgrade it to an AMD 5x86-133 ADW and the problems began
No matter on how I set the jumpers the board does not throw any video signal, just fans and hard drive spinning and that's it and also the jumper settings are driving me crazy a lot because some of them are not really accurate T-T
Games like Duke Nukem 3D tends to be choppy in 640x480 and I need to go back to 320x240 in order to play it correctly
So, anybody can help me?? I have a pair of those AMD processors and no one is getting warm unlike the 486 because the last one burns my finger in a manner of seconds
And speaking of the computer I did switch the front panel since I had an identical case, same front but different cover clipping system and also the PSU since the original one has a loose IEC connector
937.97 KiB
The computer itself
1.08 MiB
BIOS stuff and running MS-DOS 6.22
Specs in BIOS screen and the video card is a S3 Virge 375/385 with 2 megs of RAM and an ESS1869 sound card
Reply 1 of 17, by Caluser2000
What happens when you refit the 486dx2/66 cpu?
Reply 2 of 17, by treeman
is your board set to 5v or 3.3V? because the dx2 66 come in 5v and 3.3V so not sure which one you running, 586 is 3.3V only hope your not trying to run them at 5v?
also duke nukem 3d in svga mode runs just ok on 133 if you click it to 160mhz it is quiet playable
Reply 3 of 17, by Rodoko
When I configure it for a 486/66 runs great but that is because I'm using the real 486/66
For the 486/66 is set to 5v and with the AMD which does not start is set to 3.3 and the jumper configuration is different from the one in the 486
And talking of DN3D yes with 133 works great but with the 486/66 it becomes choppy
Reply 4 of 17, by canthearu
Thats pretty normal for a DX66 to be choppy in DN3D at 640 x 480. It just doesn't have the pixel pushing power needed for that mode.
At 320 x 200, a 486 DX2/66 runs duke3d pretty ok ... not amazing, but certainly playable.
I prefer a fast Pentium/Pentium II for duke3d ... can really crank it up high and run silky smooth.
Reply 6 of 17, by treeman
if the 5x86 is cold its not a good sign, do you have a motherboard to confirm 5x86 working? also try setting fsb to 25mhz for 5x86
is it Intel dx2 66 or amd? you might have to set jumpers for a amd CPU also if you have them set for a Intel
Reply 7 of 17, by bjwil1991
Actually, some AMD CPUs at that time period, the DX5-133 or Am5x86-P75, was only 3.45V, so in order to use it on a 5V line, the one way to use the CPU is a 3.45V to 5V voltage regulator that fits into the socket. Another option is to buy an Evergreen 586 that has 5V and it'll work without issues.
Reply 8 of 17, by Caluser2000
Yeah Evergeen, Hypertech or Kingston x586 upgrades have a voltage reg on the interposer. My Hypertech Hyperace 586 comes with a fan. Useful page for those interested in this type of upgrade http://www.cpushack.com/UpgradeProcessors.html
Reply 9 of 17, by treeman
so in theory under clocking it at 25fsb might help wake it up if it really needs 3.45V however I got. about 6 586 chips and none of them ever complained about running at 3.3V and most of them clocked at 160mhz
Reply 10 of 17, by Caluser2000
Looks more like he put a 3.45v cpu in a 5v system. Hence no video and fans just running.
Reply 11 of 17, by Rodoko
Nope, I just setted up the board to run at 3.3v via the jumper settings and both AMD's I have do work in an other board that I have iirc, maybe the power is not sufficient for the CPU to warm up I guess
And tomorrow or the Wednesday I'll try the 25 megs setting to see what happens
Reply 12 of 17, by treeman
another thing that comes to mind could be a faulty voltage regulator, not sending power on 3.3v need to measure with a multimeter to confirm you are getting power into socket when jumpered at 3.3v also would be good to try other slower cpu at 3.3V like dx4 100 or dx2 66 3.3v version but not everybody has alot of parts I understand that
Reply 13 of 17, by Nipedley
Probably the board came in two configurations, one with voltage regulator and one without. The board still has all the jumper settings but they do nothing, because the regulator isn't there to produce the lower voltage
Happened with me on a DataExpert board
Reply 14 of 17, by treeman
lets hope not for the sake of those 5x86 chips, he should of seen some smoke if they did burn up at 5v.
anyway this is a quick way to test if your jumpers are sending the right voltage
Reply 15 of 17, by dave343
treeman wrote:
lets hope not for the sake of those 5x86 chips, he should of seen some smoke if they did burn up at 5v. anyway this is a quick […]
😳 that board... sitting on fabric... 😳
Reply 16 of 17, by Rodoko
I tried at 25 MHz... nothing, I'll share a pic of the board's processor area
827.97 KiB
Reply 17 of 17, by treeman
looks like something missing from factory on u11 need somebody with same board that has confirmed 3.3v capability for comparison
