Reply 40 of 45, by King_Corduroy
Originally it was connected to the sound card via the Mitsumi port and everything worked before I reinstalled DOS. After fucking with it for the last few days I just yanked a cable from another computer I had and attached the CD to the motherboard. Now it works great with the new install of DOS. 🤣
Check me out at Transcendental Airwaves on Youtube! Also wtf, why are whoppers so good?!
Reply 41 of 45, by PC@LIVE
I imagined that this worked.
However the important thing is that you have solved.
Have fun.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
Reply 42 of 45, by AlaricD
King_Corduroy wrote:
OakCDROM.sys. 🤣
Which demonstrates why MTMCDA*.SYS drivers would never have worked-- those are for a proprietary interface.
Not sure why the drive didn't work where originally connected, though.
Glad it's working, that's the main thing.
Reply 43 of 45, by mav85ale
hello everyone and sorry if I reopen an old discussion.
I have a similar problem, PC Olivetti M290, IDE CD ROM connected on an Opti 82c931 (IDE PORT, not panasonic / mitsumi etcetc) ..
sound card drivers correctly installed, Port adress 168 / IRQ 10 CD-ROM.
Philips CD player 8x PCA82CR / M2.
Whichever device driver I put, I always get the cdrom not found message.
i tried Vide-cdd.sys, OAKCDROM.sys and others.
the first line of the sys config loads the CDSETUP.SYS driver which is used only to set the port and IRQ of the cd. The strange thing is that it sets the port "/ P: 36e, 168" and IRQ "I: a" (a probably stands for 10)
can you help me?
Olivetti M290 / 386SX 16MHz / 4MB / 100MB HDD / TSENG ET3000 / Opti 82c931
Commodore 486DX33C / 486DX2 66MHz / 8MB / 500MB HDD / WD90c30 / Vibra16
Pentium MMX 233MHz / 64MB / 8.4GB HDD / Millennium II 4MB / 3Dfx Voodoo / Creative SoundBlaster AWE64 GOLD
Reply 44 of 45, by mav85ale
None at all? @King_Corduroy in the end what did you leave on config.sys and autoexec.bat?
Reply 45 of 45, by AlaricD
Make sure VIDE-CDD.SYS looks for the drive on the right IRQ and port, so be sure you're setting the /P switch for that driver line correctly: /P:168,10 .
CDSETUP just activates the IDE port, VIDE-CDD.SYS then looks for a CDROM drive attached to the port you tell it to look.
https://www.vogonswiki.com/index.php/VIDE-CDD.SYS explains the switch, and what the output will look like.
D'oh: I just realized this is a massive threadsurrection 🙁
Sorry.
(I'd delete but it could still help the person after all)
