First post, by arncht
I created a new Youtube channel for old (mostly PC) demoscene demos: https://www.youtube.com/channel/UCNmJZMawB8PAEQlN2HgOwOw
On the Facebook: https://www.facebook.com/demoscenevideos
And games: https://www.youtube.com/channel/UCgdd9OPuFZC0HRXtrhgmiRw
My Facebook page (videos + hw related posts): https://www.facebook.com/mylittleretrocomputerworld
I have built 5-6 period correct retro PCs from 1994 to 2006, but I could build a config for every year of the 90s. Actually:
Socket 3 (1994): Socket 3 VLB @ 1994.10 - DX4 100, Tseng Et4000W32p, Sound Blaster Pro 2.0, Gravis Ultrasound, Roland MT-32, Roland SC-55
Intel DX4 100 WB SK096
Asus VL/I-486SV2GX4 rev 2.1 SiS 85C471 ST
Sharp 72 pin FPM 60ns 8M x2
Hercules PowerDynamite 2M VLB Tseng ET4000/W32p
Creative Sound Blaster Pro 2.0 CT1600 rev 06 ISA DSP3.02, YMF262 OPL3
Gravis Ultrasound 3.74 1M ISA
Socket 5 (1995): Socket 5 @ 1995.05 - Pentium 120, S3 Vision968, Sound Blaster AWE32, Gravis Ultrasound
Intel Pentium 120 SY033
Intel Advanced/ZP Intel 430FX
Micron 72 pin EDO 60ns 8M x2
Matrox Millennium 4M PCI
Creative Sound Blaster AWE32 CT3910 rev 01 ISA DSP4.13, CT1747 OPL3
Socket 7 (1997): Socket 7 @ 1997.09 - Pentium MMX 233, Nvidia Riva128, 3Dfx Voodoo, Sound Blaster AWE64 Gold, Gravis Ultrasound P&P
Intel Pentium MMX 233 SL27S
Asus TX97-X rev 3.00 Intel 430TX
LG PC66 SDRAM 15ns 32M
Asus 3DP-V3000 4M PCI rev 1.03 NVIDIA Riva128
Diamond Monster 3D 4M PCI 3Dfx Voodoo
Creative Sound Blaster AWE64 Gold PnP CT4390 rev 01 ISA DSP4.16, CQM
Gravis Ultrasound Plug & Play 1.0 8M ISA
Slot 1 (2000): Slot 1 @ 2000.05 - Pentium III 1000, Geforce 2 GTS, 3Dfx Voodoo2, SB Live!, Gravis Ultrasound P&P
Intel Pentium III 1000EB SL4BS
Asus P3B-F rev 1.04 Intel 440BX
Mosel Vitelic PC133 SDRAM 7ns 256M
Asus AGP-V7700 TVR 32M AGP NVIDIA GeForce2 GTS
Diamond Monster 3D II 12M PCI 3Dfx Voodoo2
Creative Sound Blaster Live! CT4620 PCI
Socket A (2003): Socket A @ 2003.06 - Athlon XP 3200+, Radeon 9800 Pro, Sound Blaster Audigy 2
AMD Athlon XP 3200+ AXDA3200DKV4E
Asus A7N8X Deluxe rev 2.0 NVIDIA nForce2 Ultra 400
Samsung PC3200 DDR 256M x2
Sapphire Atlantis Radeon 9800 Pro 128M AGP ATI Radeon 9800 Pro
Creative Audigy 2 Player SB0240 PCI
Socket 775 (2006): Socket 775 @ 2006.11 - Core 2 Extreme QX6700, Geforce 8800 GTX, Sound Blaster X-Fi Fatal1ty
Intel Core 2 Extreme QX6700 SL9UL
Asus P5W DH Deluxe rev 1.04 Intel 975X
Corsair XMS2 DDR2 800 1G 2x
Asus EN8800GTX 768M PCIe NVIDIA GeForce 8800 GTX
Creative Sound Blaster X-Fi Fatal1ty SB0460 PCI
The capture card: Datapath VisionRGB-E1S
I developed a capture tool which is suitable for the continuous mode switching and the freak modes (320x256, etc). I develop the tool parallel with the uploads, and I try always to improve it - so I expect better and better quality.
Bought this retro hardware
Reply 1 of 189, by arncht
Mortal Kombat (1993) @ Sound Blaster Pro 2.0
Doom II: Hell on Earth (1994) @ Roland SC-55 Sound Canvas
The Lost Vikings (1993) @ Roland SC-55 Sound Canvas
Alone in the Dark (1992) @ Sound Blaster Pro 2.0
Silverball (1993) @ Gravis Ultrasound
Extreme Pinball (1995) @ Gravis Ultrasound
MFX - Dose 2 (2001) demo 2160p60
Dubius - Machines of Madness (1996) demo 2160p60
CNCD - Inside (1996) demo 2160p60
Pulse - 73 Million Seconds (1998) demo 2160p60
Orange - The Secret Life of Mr. Black (1997) demo 2160p60
Reply 4 of 189, by Rawit
Really great to see hardware captures of all these demos. A question though: do you get better results with 2160p60 instead of 1440p60? Better playback on devices? Because scaling wise 1440p looks better on paper:
- With 640x400 sources you can do a nearest neighbour scale to 1920x1400. Add 40 pixels of borders or do a last bilinear scale step to 1440;
- With 640x480 sources you can do a nearest neighbour scale and you're done.
My build: Speedsys
Reply 5 of 189, by arncht
because of the youtube compression 2160p is better... and at the upscale filtering always filter the multiplied resolutions too (i dont understand why). another problem, because of the buggy capture card firmware, the 640x480 bottom 5px lines are missing, so it is technically cropped 640x475. the 640x400 is not 4:3 - you need to filter it to get the right aspect ratio.
actually this is the best quality what i could achieve - i use the purest 1:1 output resolution, and the obs do the gpu based upscale. it would be nice to capture the original resolution if the youtube would support the lossless video format, anyway we could see just the video artifacts instead of the "pure" pixels.
at my capture/view tool i plan to use the "closest" multiplied resolution, but it is not ready yet. i will do more testing, how could we get back the pure pixels, without blurring. eg it would be interesting to rebuild the image with custom sized pixels.
i use a smaller resolution, if it is high resolution enough and native - eg the real 1080p content.
Reply 6 of 189, by elianda
As inefficient as it may seem, the higher video resolution on youtube, the better bitrate you get. As the upscaled low res source material does not add as much content as the bitrate gain increases, you get better quality on YT.
Generally for non-square (though works also for square pixels) a good approach is first to scale up nearest neighbour by an integer factor, such that the image is at least twice larger than the final resolution. Then downscale it to the final resolution in the correct aspect ratio, e.g. 1440x1080 for 4:3. By choosing a suitable algorithm for downscale you can decide how sharp the final upscaled pixel edges will be. Consider that also on a CRT the pixel edges are not 100% sharp.
If the source material is RGB 8:8:8 it is also important to do the scaling before converting to YUV color space. (YT converts to YUV, as well as x264 without RGB enforcement). Just low res lossless support on YT wouldn't do, it must also be RGB. YUV kills small vertical structures.
@arncht: When your application captures, does it cope with source fps changes? Like 720x400 70 Hz to 640x480 60 Hz mode changes. Does your output video stream contains these variable frame to frame times?
I just wonder because most capture applications run on fixed fps once setup.
I have a small gallery of system I used to capture from:
http://retronn.de/imports/computer_overview.html
with the IBM PS/2 on an extra page: http://retronn.de/imports/ibm_pc.html
as well as the NexGen system: http://retronn.de/imports/nexgen_nx586.html
Youtube Channel
Reply 7 of 189, by arncht
The tool has three view modes, the first is the capture mode, it fixes the output resoluton to 1:1, and at the input changes it follows automatically the input source. It also possible to follow the frequency too, but i maximized the readouts to 60 fps.
At another view modes i keep the original frequency, because i want to syncronize with the freesync. In this case it is super smooth, like the crt.
I use my tool just for the view, the obs captures the window. But does it make sense to deal with the variable frame rate with the youtube share?
Reply 8 of 189, by Rawit
I will try this out when I have time. The recipe I posted is being used by Nerdly Pleasures and those captures look very crispy. I do wonder if the bitrate gain is worth the extra non-integer scaling that is being performed. With limited motion probably not, but some demo productions / FPS games might need it.
My build: Speedsys
Reply 9 of 189, by arncht
the capture and the youtube are two different stories 😀
i have tested the filters, first i chose the "sharpest" but later i switched to the bicubic. it looked more natural to my eyes.
Reply 11 of 189, by xjas
^^ what the hell? It's like they had 2/3 of a really good demo together, ran out of ideas, and got stoned off their gourds listening to old Abba records two nights before the compo. What were they thinking?? Nice software renderer though.
twitch.tv/oldskooljay - playing the obscure, forgotten & weird - most Tuesdays & Thursdays @ 6 PM PDT. Bonus streams elsewhen!
Reply 14 of 189, by xjas
These look really good! That one must have been pretty brutal on the encoder, with all the fake tape noise & checkerboard fades. Love the punk style.
Also, thank you SO MUCH for not adding fake black bars to the sides & forcing a 16x9 viewing window! Enjoying the FULL SCREEN captures on my 1600x1200 monitor. 😀
Reply 15 of 189, by arncht
you are welcome! i try to give back, how did it look in the past, but parallel focus to the "smooth" experience.
Fudge - Alien Sex Clone (1998) 64k intro 2160p60
Reply 16 of 189, by elianda
Actually the aspect ratio issues are more of a youtube problem. As quite a few low res DOS resolutions do not have square pixels there are different approaches:
- encode in original resolution and set 4:3 aspect ratio in the video container
example: https://www.youtube.com/watch?v=bQa0Ea2GITw
(with YT the bitrate vs resolution problem adds up, but thats not the point here)
- rescale original resolution to a 4:3 resolution assuming square pixels (like 1440x1080), optionally set also 4:3 aspect ratio in the container
example: https://www.youtube.com/watch?v=r4eUHxCv3Lc
- rescale to a common 16:9 resolution like 1920x1080 and add black bars. Let YT automatically deduce that 1920x1080 is 16:9.
From my personal experience only the last option worked reliably with youtube. For my local videos I prefer the first option.
With the first or second option I have seen that Youtube often decides to put the video into 16:9 aspect ratio ignoring any video container setting.
It seems that recently the aspect ratio awareness of YT got better, thus the examples above actually show in 4:3 AR now.
Usually information by YT about the features supported in such details are rare and in my former tests I even had the impression it depended in which YT server delivers the video stream.
If the AR is converted reliably now, maybe it is worth going back and scale to e.g. 2880x2160 for 4:3 without vertical letterboxing.
@arncht did you recently experienced any problems that YT did not evaluate your AR setting?
Funnily enough the native video support by current browsers is well aware of AR settings, such that on my own page it works very well: http://retronn.de/imports/dosvideo_quick_access.html
Youtube Channel
Reply 18 of 189, by arncht
Blasphemy - Moralhardcandy (1999) demo 2160p60
The Lost Vikings (1993) @ Sound Blaster Pro 2.0
Reply 19 of 189, by arncht
Elitegroup - Kasparov (1999) demo 2160p60
Wing Commander: Privateer (1993) @ Sound Blaster Pro 2.0
