identify a compaq motherboard
Postby weldum » 2019-6-12 @ 14:08
hi, i have a compaq motherboard, is i440bx based, with 4 pci, 2 isa and 1 agp
Aida64 says that is a Compaq Ep/Sb, whatever it means
i want to know if it's based on another motherboard, like the compaq camaro that's based on the mitac 5114vu
that way i can flash the original bios
also, the motherboard has random crashes in both windows and dos, what it could be?
Ohh, the humanity :depressed:
386SX 25-C3 800-P3 900-Atom 1.6-C-D 2.13-P4 2.26-P4HT 3.0-P-DC 1.6-AFX 2.6-FX 3.3
User avatar
weldum
Re: identify a compaq motherboard
Postby appiah4 » 2019-6-12 @ 14:37
It's a Compaq Deskpro EP motherboard, one of the earlier Slot-1 versions. I believe that one is actually based on an Intel motherboard.
There are also 3 PCI mATX i810 Socket 370 ones that lack AGP slots for that system.
A500:Rev6|+512K|ACA500+|C1084S
i386:Am386SX25|4M|GD5402|ES688|MuntPi3
i486:U5S33|8M|GD5428|YMF719|DB-S2
i586:P133|32M|T64+/MX2|V1|CT3980/32M
i686:K6-2/400|128M|V2/SLI|CT4520/32M
S370:P3-1200|384M|GF4-4200|MX300
S754:A3700+|2G|X1950PRO|SB0350
User avatar
appiah4
Postby weldum » 2019-6-12 @ 14:39
yes, i had the i810 based motherboard, was really good, sadly a bad psu killed it
i should search in the intel page then, there may be a way to use a pentium 3 on that board
User avatar
weldum
Who is online
Users browsing this forum: Disruptor, knowledge [bot], MMaximus, scroeffie, SSTV2, zyga64 and 17 guests
