First post, by _ar
Do any one of you have the manual for the Rev 1.7 by any chance? I only found jumper settings for the rev 1.1 and 2.0 board, but the 1.7 looks different. Any help is appreciated! Thanks!
A while back I made a post regarding version 1.8, it has details on what certain jumpers do. I suppose 1.7 is pretty much the same:
ASUS VL/I-486SV2G(X4) REV. 1.8 conversion and jumpers guide
I only mention the jumpers that are different, the rest should be the same as on the 2.x manual.
Yes, looks identical to mine.
wrote:Yes, looks identical to mine.
Thanks! I also found that the jumper setting for the rev 1.1 pretty much applies for the 1.7 as well.
