First post, by Kiteless
Greetings, been coming to Vogons for about a year now and getting deeper and deeper into old computers, I finally created an account I'm finally putting together my dream 486 DX4. I picked up a Trident TGUI9440 via eBay and have a bunch of other parts on the way. At some point there was a a driver pack uploaded over here:
Re: Windows 3.1x & Windows NT 3.51 Graphics Card Drivers Collection
But the links no longer work. Does anyone still have that file they can upload over in the drivers section? Also anyone know of Windows 95 drivers for this card or maybe they come baked in? I thought I ran Windows 95 on my 486 and it had a Trident VLB card in it.
Thanks so much for any help. At some point I need to do a intro post with my collection.
// K
YouTube channel
https://www.youtube.com/channel/UCTfnRX4AWhbYJuguUcEff-g
Main Systems
NuXT
IBM 5140
486 DX4 100Mhz (Mainly DOS)
AMD K6-2 500Mhz (Mainly DOS)
AMD Athlon 700Mhz 9700 Pro (Win 98)
Pentium D 3Ghz 4670 AGP 8x (Win XP)
Reply 1 of 10, by bakemono
these should be the ones
    trident.zip
    1007.05 KiB
    436 downloads
    w95-9440.exe
    183.9 KiB
    255 downloads
Reply 2 of 10, by Kiteless
Woo thank you! I'll wait till I verify these (it will be a week or two before I get all the parts together to make my 486) then if it's OK I will stick these over in the drivers section with credit to you. Cheers!
// K
YouTube channel
Main Systems
NuXT
IBM 5140
Reply 3 of 10, by Kiteless
Not sure if I should start a new thread, but to keep things tidy I'll start here first.
SO I finally have my 486 build coming together. The Trident TGUI9440 VLB went in and is working perfectly. For now this machine will be mainly DOS, but Win 3.1 installed as well. I installed the Win 3.1 drivers within Windows on a brand new install, right off the floppies. 😁 But the machine hard locks when Windows tries to load with tha TGUI 9440 or the non-TGUI 9440 driver installed.
I initially tried 1024x768 256 colors. I reset the default 640x480 driver with SETUP.EXE and tried 800x600 256 colrs, then 640x480 16 colors. All result in a hard lock.
WIn 3.1 works fine in 256 color VESA 800x600, but a bit slow since it's not accelerated. Also a hald full of DOS games I have installed work fine. So I think these are not quite the right drivers for my card or there's something wrong with my card.
The README talks about "AGi" Looking around I believe there is a TGUI9440AGi specific card? Mine is the non0AGi version.
Any help would be greatly appreciated. Over the weekend I'm going to try a Windows 95 install (for funzies) and see if the WIn95 driver posted here gives any better results.
Cheers!
YouTube channel
Main Systems
NuXT
IBM 5140
Reply 4 of 10, by bakemono
There should be drivers for 9440 and 9440AGi, as well as 512KB and 1MB cards. By any chance does your system have 64MB of RAM? That might prevent it from allocating a linear framebuffer. That's the only thing I can think of.
Reply 5 of 10, by Kiteless
Wow this seems to exactly fixed the issue. I don't think I would have ever tried removing one of the modules. Not that it would be terribly fast but would this issue still happen in Windows 95? Is this issue specific to Trident cards? If I added another meg of ram to the card could that allow me to run 64megs of ram and still get acceleration?
Also the driver seems to offer Trident and Trident 9440 but doesn't say anything about AGi specifically in the driver names.
Thanks again for your help.
YouTube channel
Main Systems
NuXT
IBM 5140
Reply 6 of 10, by bakemono
The win95 driver probably also needs a linear framebuffer (the driver name says "linear accelerated"). The problem is that it normally is located at 63MB and it can't go higher. It's just a limitation of this Trident chip. So if you have 64MB of RAM it blocks off that area.
The readme file says it can be moved but only between 18MB-63MB. So the "memory hole" BIOS option used by some other cards may not work either since that would be at 15MB.
Reply 7 of 10, by Kiteless
Dang you know your stuff. Thanks for all this info. It's very helpful! Cheers!
YouTube channel
Main Systems
NuXT
IBM 5140
Reply 8 of 10, by Marco
Hi all
I’m having similar issue. My trident 9440 won’t install on win95. Only the Microsoft trident svga driver are working. The drivers here in the library always lead to “not working... consult supplier for other driver. I was having 64mb ram so I removed half of them due to above message. Unfortunately the same issue. Strange.
Do you have further hints?
Edit: I found an older version in the web. Don’t know why but that one worked. Maybe I will try now again with 64mb. Aaaa better not 😅
1) VLSI SCAMP 311 | 386SX25@30 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | SG NX Pro 16 | LAPC-I
Reply 9 of 10, by AvocadoLongfall
Marco wrote on 2020-07-03, 22:45:
Hi all […]
Hi all
May we please have a link to that version?
Reply 10 of 10, by Marco
Hi, I dont have right now the time to check in detail which source it was. So I attached all the drivers I own. One of these should work. Good luck and let me know whether one of them worked
    TG4400_W95.rar
    1.3 MiB
    42 downloads
