First post, by dave343
- Member
I picked up a AMD K5 PR100 today, but I've come to read the original K5 CPU's were not as fast as the later models, due to the fact AMD had the branch prediction unit disabled. What I'm confused about is that AMD re-released the K5 cpu's with the Brand Prediction unit enabled, and re-badged the CPU's to just say K5, and not SSA/5. I think... all 75mhz and 90mhz versions were SSA/5 even if they were re-badged, but does anyone know if the PR100 CPU's always remained SSA/5 or did AMD enable the BP unit and like all faster K5 CPU's, just call it K5. I've searched CPU-World, the Anandtech K5 article, Wikipedia, but the info isn't clear, except to say AMD re-released the CPU's under the K5 naming sceme once they fixed the 2nd round of K5 cpus.
Mine is the AMD K5-PR100ABR. Anandtech says it was re-released as a PR100 (75mhz), but I can't find anything about that anywhere else. Wiki just states that they fixed the K5's and turned on the BP unit starting at PR120 CPU's, but a few other websites say AMD re-released the PR100 CPU too, but the newer version has the BP unit turned on, making it a lot faster.
