AMD 5x86 P75 without heatsink?
Discussion about old PC hardware.
Postby AlessandroB » 2019-7-12 @ 15:56
i have read in many places that this chip can work without cooling system... is true? Mine is labelled on top “heatsink and fan required” :neutral:
AlessandroB
Re: AMD 5x86 P75 without heatsink?
Postby Tiido » 2019-7-12 @ 16:08
You pretty much always need a heatsink and a fan is highly advisable if the heatsink isn't particularly big. These chips do get pretty hot even at 3.3V.
User avatar
Tiido
Postby AlessandroB » 2019-7-12 @ 16:49
But... there is a version that not require cooling system?
AlessandroB
Postby Deksor » 2019-7-12 @ 17:15
No.
Deksor
Postby AlessandroB » 2019-7-12 @ 17:24
ok i get it, as soon as i can unplug the DX2 I see to insert the 5x86 and try to see how it works. tnks guys
AlessandroB
Postby Tiido » 2019-7-12 @ 17:54
You need a board capable of 3.3V before you can use the 5x86. Chances are that your board is 5V only and that will fry the 5x86 sooner or later. Can you show a photo of the board ?
User avatar
Tiido
Postby AlessandroB » 2019-7-12 @ 18:14
My board is capable for sure, the only cpu that can’t handle is the Pentium Overdrive. Is a SBC 486 really good equipped. The only bad thing is that not have a ZIP Socket and i must use some tool to detach the DX2 Cpu that is actually inserted
AlessandroB
Return to General Old Hardware
Who is online
Users browsing this forum: Anonymous Coward, Big Pink, knowledge [bot], Lazar81, sainrub, silentw, the3dfxdude, Xicor and 17 guests
