First post, by AlessandroB
Yesterday i try to swap different Pentium MMX in my SBC to find wich one is locked, after 10/15 Carefully CPU swap, tryng different multiplier, frequency ecc... the system whont boot!!! It Stop on
Updating ESCD... Success
Building DMI Pool
I have try to load bios default but nothing suceed... there is not on the SBC a reset bios jumper...
I'm terrified.... can I have broken the mainboard only by changing the CPU and trying to see which one was blocked? I have always done everything with extreme care and attention
My SBC is that one: PROX-1560S-N withot SCSI module installed
Thanks guys...
Reply 1 of 4, by AlessandroB
Really guys.. i can destroy a new Board only trying out ten CPU???
can anyone help me? will you post some images of the bios ???
Reply 2 of 4, by derSammler
Of course you can. A simple ESD is all that is needed to damage or destroy electronics. However, no one can really answer that based on your information.
It there a battery (coin cell) on the SBC? If so, remove it and short the battery terminals for some seconds. That should zap all BIOS settings. Also, try with no other cards installed apart from those really needed (which should be none for an SBC).
Reply 3 of 4, by retardware
With some BIOSes you explicitly to enable "Update ESCD Data" after hardware changes, or it won't update (and not run in consequence).
And yes, ESD is a killer. I am often amazed how little many people care until the expensive damage they caused made them change their behavior with microelectronics.
Reply 4 of 4, by AlessandroB
There is a Dallas DS12C887 that i put out for half days, is enough to reset the bios settings???
edit: i have read that is the chip dallas itself that store the bios settings, so put out not reset anithyng. I must buy a new one to test????
