First post, by Intel486dx33
Hi, I need a manual or jumper settings for this VLB controller
It’s a Data Technology model # DTC2278D
There are several online but not the right one.
Mine has 2 IDE channels.
Reply 1 of 15, by GigAHerZ
Did you even try to google it yourself!?
Reply 2 of 15, by Intel486dx33
Actually, I found a some what similar manual.
https://stason.org/TULARC/pc/hard-disk-floppy … erface-293.html
I have floppy drive and parallel port and serial ports working but the IDE ports are not working.
Any Ideas?
The motherboard I am using is a Gigabyte GA-486vs.
I already swapped out IDE cables and hard-drives.
The problem appears to be with the controller itself.
Reply 3 of 15, by GigAHerZ
https://arvutimuuseum.ee/th99/c/C-D/20836.htm
Reply 4 of 15, by Intel486dx33
These manuals don't address the reason why the IDE ports are not working.
There are No jumper settings to enable/disable IDE ports and No DMA setting options for the IDE controller.
Reply 6 of 15, by Intel486dx33
That package just has drivers and install readme.txt
I need to get the IDE ports working first. I can’t even setup the hard-drives in bios without the IDE ports working.
What could be causing the IDE connectors not to work ?
Reply 7 of 15, by PC Hoarder Patrol
Although there don't seem to be specific IDE jumpers listed, have a look here
https://web.archive.org/web/19970503163558/ht … nuals/2278d.htm
https://web.archive.org/web/19970503160814/ht … als/manuals.zip
Also have a look thru the FAQs and Troubleshooting Tips
https://web.archive.org/web/19970503155857/ht … rt/tech_sup.htm
Reply 8 of 15, by ZipoBibrok
Have you tried the card on different VLB slot on motherboard? Some motherboards have slots labeled master and slave and some cards require a master slot. Only the IDE controller part of the card is in VLB bus anyway, so other functions would work even if the motherboard or the IDE controller chip on the card was defective. Also check JP20: Delay CPU Clock, JP29: VL-Bus Speed Configuration and J2, J8, J9: Delay Local Bus Clock jumpers on the motherboard.
Reply 9 of 15, by Anonymous Coward
I think I might have this card CIB. Not sure if it's the D version. I'll see if I can find it.
Reply 10 of 15, by Intel486dx33
The motherboard manual reads that I can use any VLB slot for master/slave.
I am going to clean the contacts on the controller card and try again.
I tried the delays but it did not change anything. I will try again.
Reply 11 of 15, by Intel486dx33
Okay, I have it somewhat working. But has trouble detecting my drives.
I think the problem is with the motherboard now.
Is there a new bios ROM update for this motherboard and is the bios chip flash-able or do I need a new chip and eprom programmer ?
The PCB on the IDE controller has this number # 400503-97 , PCB rev. B
But I don’t see it in the list of manuals.
Am I suppose to enable or disable “hard drive block mode” in bios ?
For timings I an using 1/4 , with wait states 0.
I have a Intel 486dx4-100 CPU installed.
Reply 12 of 15, by ZipoBibrok
http://th2chips.freeservers.com/ga486vs/index.html
It's usually better to disable it if you install the drivers for the controller I linked earlier.
Reply 13 of 15, by PC Hoarder Patrol
Despite the backplate label saying the model is 2278D, I now see the pcb says 2278S/D (below the IDE port) which is a slightly different layout
https://web.archive.org/web/19990508184740/ht … 8/2278sd3.shtml
Did you look thru the FAQ I listed earlier, as it says
CMOS settings...disable IDE Block Mode and 32-Bit transfer options if enabled. Enabling these options in CMOS conflicts with the DTC drivers which turn on these options.
Reply 15 of 15, by Disruptor
I can give you my jumper setting for the DTC-2278D
W17 1-2, W16 1-2, W15 NC, W14 NC, W13 1-2, W12 NC, W11 NC, W10 1-2, W9 NC, W8 1-2
W7 no jumpers possible, W6 2-3, W5 1-2, W4 2-3, W3 1-2, W2 1-2, W1 2-3
