First post, by MKT_Gundam
- Member
I updated the p3v133 to lastest bios- 1003.002. On Asus site, this motherboard is compatible with 1ghz p3.
The manual only inform jumper setting until 733mhz 133fsb.
My slotket is this one Help with Slotket
The sloket only has jumper for 100/133fsb and forcing (overclock) the fsb jumper
I have the 733 but really wanted put the 1ghz but no idea if the slotket will work or even the proper jumper configuration for the p3.
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
