First post, by Intel486dx33
I can seem to get this card to work.
I need the correct manual for it.
I think it was made by a Canadian company.
It is an Acculogic sIDE-4/VI VLB controller card.
I found this but it is not complete.
https://stason.org/TULARC/pc/hard-disk-floppy … -SIDE-4-VL.html
Does anyone have any info on the jumper settings for this card ?
Right now it's non-functional without the correct jumper settings.
It looks like a nice card. I would hate not being able to use it.
Intel486dx33 wrote on 2019-07-23, 21:14:Does anyone have any info on the jumper settings for this card ?
Anybody find out anything else about this board? The one with the serial port connected directly to the PCB (not though a short ribbon cable?) I have floppy working, and managed to figure out how to set the addresses for the comm and parallel ports so far. I can get the VESA IDE controller to recognize a CF card, but something's wonky because DOS/FDISK will see the drive, allow you to partition it, and then as soon as you reboot, the partition table you've created is gone (which makes me think it was never saving it in the first place...)
