First post, by Zup
- Oldbie
I've got a Toshiba Satellite Pro 4340 that I received without HDD. I've upgraded that computer (maxxed RAM to 320Mb and mounted a 40Gb IDE HDD). It has DOS, Windows 98SE and Puppy Linux 5.28 installed.
The laptop has a TEAC CD-224E CD reader, and yesterday I found in a "share" bin a Sony CRX880A DVD reader/CD writer combo (taken from a server). It seems to be an IDE combo, but it has a SATA to IDE server adapter.
So I get rid of the adapter and put the DVD in my laptop... IDE #1 error. According to google, it seems that Toshiba laptops only works with IDE devices configured as master (but most devices are configured as CS). I've found some utilities that can patch the firmare and configure it to work as master, slave or CS.
...but I don't know how can I make it work.
- I've got only a laptop with IDE bus, and the BIOS can't detect it. It doesn't show in DOS, Windows or Linux, so I guess the utilities won't work on that laptop.
- That DVD has a "laptop" style (1 inch size) connector, and I don't have any adaptor to normal IDE connectors (either 40 or 44 pin).
- The IDE to SATA adapter (a Dell one) has a normal SATA data connector, but does not have normal SATA power connector. It has a small 4 pin connector, but I don't know how to connect a PSU (and if I make it work, I don't know if an utility will find the drive connected on a SATA port).
Has anyone got any suggestion?
Thanks.
