First post, by retropol
Hi Guys,
I have a 486 with only one IDE on the mobo. Both connectors are used now - one for hdd, second for cf card.
I need to setup cdrom, so decided to use 2ND IDE from soundcard:
download/file.php?id=62442&mode=view
how to make it working on dos and win3.11?
Reply 1 of 8, by Intel486dx33
I had the same problem.
See this thread.
CT2950 with IDE CDROM not working ?
I downloaded this CD-ROM driver “VIDE-CCD.SYS” which worked well.
https://sites.google.com/site/pcdosretro/vide-cdd
Extract and copy to C:\
Edit you autoexec.bat and config.sys files
Autoexec.bat
MSCDEX.EXE /D:MYCD01 /L:D
Config.sys
DEVICE=VIDE-CCD.SYS /D:MYCD01
Reply 2 of 8, by retropol
hi thank you will try it, btw- in your thread there is no word about VIDE-CCD.SYS - you are suggesting VIDE-CCD.SYS so is this any improvement in comparison to the original suggestions from your topic?
Reply 5 of 8, by Grzyb
Quoting the README.TXT file from the attached package...
Problem:        Cannot load IDE CD-ROM drive.
Cause: IDE port is not enabled. Check the config.sys file under
C: root directory and you should see "device=c:\alsound
\cdsetup.sys" before loading your CD-ROM driver. The
cdsetup.sys enables the IDE port.
Solution: Run c:\alsound\alconfig.exe again and select the CD-ROM
IDE. When you leave the alconfig program, device=c:\alsound
\cdsetup.sys will be added to config.sys. Make sure
that this line is before loading the CD-ROM driver.
    w95_007.exe
    756.95 KiB
    6 downloads
Reply 6 of 8, by retropol
Grzyb thank you.
This card has no jumpers, question what addr, irq and dma is it working on? Do you know? ALS007 - FCC id: MA5ASOUND.
For now - i tried different combinations in a cannon fodder 2 setup and no success.. 😒
Reply 8 of 8, by PC@LIVE
Some time ago I suggested how it works on my PC.
I solved by loading these two lines in config.sys:
Device=C:\awsound\cdsetup.sys /P:220
Devicehigh /L1:,23888 =C:\oakcdrom.sys /D:MSCD000
While in autoexec.bat I have the following line:
set BLASTER=A220 I5 D1 T4
LH /L:1,27952 C:\dos\MSCDEX /D:MSCD000
The sound card is an ALS100 ISA and the CD-ROM is an IDE.
In my opinion it is possible that it also works with other sound cards and CD-ROMs, but it is possible that different drivers are needed from those I use.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
