First post, by Lostdotfish
After a little advice/sanity check on hardware selection for my in progress retro build. The system is based around using my MT-32, so a mix of DOS and Win98SE.
Video - the motherboard bundle is coming with an ATI Rage II DVD PCI card. I'm not hearing great things about this card. Planning to change to a Voodoo 1 and Matrix Mystique. Is this a good choice? Any other suggestions? Should I give the Rage II a chance?
Audio - again, the board bundle I've picked up is coming with an ESS ES1868F. I've heard reasonably good things about this card. Should I pick up a Music Quest MPU 401 clone and call it a day or should I consider another audio card?
Thanks all.
