Reply 460 of 1037, by red-ray
- Oldbie
repaxan wrote on 2020-05-23, 20:51:tRFC reported in the BIOS (auto timings) is 59, which is what it should be, based on the SPD.
Thank you, looking at the logs the nForce fan speed now seems stable, but it was 8 times what it should be so I have adjusted the scaling in the attached SIV64X V5.49 Fans-03, looking at [Status] does it now look to be correct?
With all the other fans they are reported via the Nuvoton W83627DHG which directly reports the RPM so I don't need the -DBGMCH log for them and just needed to ensure the names are correct.
By searching the save file for 0x3B (59) I am pretty sure I found where tRFC is reported, Fans-03 should report Row Refresh Cycle Time (tRFC) 59 on the initial screen and if you change the setting in the BIOS the updated value should be reported.
I think I have now fixed all the issues so please may I have a new save file generated after SIV has been active for >= 10 minutes so I can check before I release Beta-03?
