HWiNFO support of vintage hardware
Reply 680 of 683, by hasat
Something interesting happening here: When i run old AIDA32 or current version AIDA64 and then Hwinfo32, all voltages and fan speeds are detected by Hwinfo32. It looks like AIDA somewhat reconfigure LM79 monitoring chip. After computer has been power off and on again, everything with sensors are again broken until i run AIDA. In attached ZIP file are new set of log files after "repair" with AIDA and sensor dump from AIDA64.
Reply 681 of 683, by Mumak
hasat wrote on 2024-04-21, 11:19:
Thanks! I think I know what the problem is. Will be fixed in the next build.
Reply 682 of 683, by Grzyb
MAC address is 48-bit, but HWINFO displays 64 bits:
5.02 KiB
3.07 KiB
Żywotwór planetarny, jego gnijące błoto, jest świtem egzystencji, fazą wstępną, i wyłoni się z krwawych ciastomózgowych miedź miłująca...
