Reply 420 of 681, by vutt
Mumak wrote on 2020-10-19, 10:06:Q: Separate one. I was wondering why your tool is giving so little info (just name, no memory sizes or clock) on my Gainward Dra […]
Q: Separate one. I was wondering why your tool is giving so little info (just name, no memory sizes or clock) on my Gainward Dragon 3000 Voodoo 2 card. Is it because I'm using nonstandard 3dfxzone.it Fastvoodoo v4.6 driver or is it about my specific hw version.
--------------Thanks for the feedback.
Yes, that issue might be due to using a non-stanadard driver. With standard drivers it should report memory size and clocks too.
If you can post a dump of the registry "HKEY_LOCAL_MACHINE\Software" key I will look into that.
Do you really need my full software library listing? You are I suppose interested only about [HKEY_LOCAL_MACHINE\Software\3dfx Interactive] content...
So here we go, regedit export attached.
Sidenote: I have done a lot back and forth testing with current win98SE install. So general state of win drivers might be affected. For example I tried to install Gainward original ver 1.0 drivers and while it didn't give any errors games just didn't work. So I uninstalled everything. Removed all voodoo .inf files from windows\inf\others dir. Even removed [HKEY_LOCAL_MACHINE\Software\3dfx Interactive] key. Then did new clean install with fastvoodoo2_4.6 drivers.
All games and 3dmarks I tested worked without a hitch.
