Reply 41 of 48, by rishooty
comteck123 wrote on 2023-01-19, 06:02:
rishooty wrote on 2019-09-14, 10:48:
It's done. All the update packs I've made so far are now stored in the public pcloud link here: https://my.pcloud.com/publink/s […]
https://my.pcloud.com/publink/show?code=kZ8V2 … UjgXpSlYFMkzvAy
A direct link to the Windows 98 Vogons Approved Update Pack:
https://my.pcloud.com/publink/show?code=XZRJ2 … uOXnOfxSpENdNQk
Final Results:
  • 98KRNLUP.EXE (Fixes Stack Corruption)
    98UPDSYS.EXE (Updates Intel CPU Microcode)
    4756US8.EXE (The classic shutdown supplment)
    236926USA8.EXE (Fixes prematurely transmitted packets)
    239696usa8.exe (Fixes hanging after suspend)
    240075up.exe (Fixes usb issues with AMD CPU + VIA USB Controller)
    241052usa8.exe (Fixes issue with password screen)
    249146usa8.exe (Fixes Disabled Sounds with usb devices)
    249635usa8.exe (Fixes an ambiguous error with usb drivers)
    253697USA8.EXE (Fixes OpenHCI Controller issues with fast pcs)
    258680usa8.exe (Fixes hang upon screensaver)
    272621usa8.exe (Fixes Virtual Memory tab showing negative HD free sizes)
    273017USA8.EXE (Fixes Scandisk running on every boot)
    274175usa8.exe (Fixes copy errors when 8 levels deep in a CD/DVD)
    278368usa8.exe (Fixes a memory leak with ATMUNI.SYS)
    281533usa8.exe (Fixes USB Driver Trap 14 error)
    290831usa8.exe (Update 273017USA8)
    291362usa8.exe (Fixes hanging with USER32.DLL + USER.EXE)
    293793USA8.EXE (Fixes Vredir Errors)
    306453usa8.exe (Fixes USB Stop Error)
    aspi_471a2.exe (updated ASPI drivers)
    bhdd31.zip (120gb+ hdd support)
    dst_9xme.exe (Updates timezone daylight savings to 2011)
    iosys98.exe (2GB+ DVD support)
    Q240896.EXE (Fixes OpenGL IPF error)
    Q246817.EXE (Update to the shutdown supplement)
    Q253912.exe (1GB RAM support)
    Q257821.EXE (Fixes winsock time-out error)
    Q269604.EXE (Fixes Directsound Error with DSOUND.DLL)
    Q277628.EXE (Fixes an ambiguous "access denied" error with VFAT.VXD)
    Q310695.EXE (Fixes an ambiguous error with DVD playback)
    Q311561.exe (Fixes potential HDD corruption in MS-DOS mode)
    Q926247.EXE (Fixes SNMP Memory corruption)
    qfe-winse-q245065-en.zip (Fixes an ambiguous error with usb keyboards)
    scanfrag.exe (120gb+ hdd support)
Can you provide a more up to date link?
Everything is in the first post, I updated it recently and the file is named accordingly in the shared folder.
matti157 wrote on 2023-01-19, 10:20:
But does Q253912 do the same thing as the rloew patch?
It does not, his work wasn’t public domain at the time so I couldn’t include it. You can grab the CAB version and drop it in with the other patch files to overwrite the existing one in the /win98 directory.
I’d like to remind everyone that this is no longer supported, and there are much better utilities and remasters out there, although mine might be easier.
Razorback95 has incredible remasters of win95 and win98. The latter is still in alpha and development is going to slow from what he’s told me, but it’s still incredibly solid despite it.
As an alternative, windows 98 dream edition is made by a related group and is also pretty solid, but it isn’t minimalist by design (think unofficial sp3 and beyond stuff for kernelex, etc).
He also has a slipstream utility quite a bit better than mine, but it uses a bootable Linux iso.
Reply 42 of 48, by comteck123
rishooty wrote on 2023-01-19, 14:51:
Everything is in the first post, I updated it recently and the file is named accordingly in the shared folder. […]
Final Results:
Thanks! I would like to mention though, the 2011 daylight savings patch seems to have problems with me. It kind've bricks the time/date control panel rendering them unusable, at least on 86Box and PCem.
The Shadow Warrior Mod that makes weapons O.P., plus adds more ammo: My First Shadow Warrior mod.
Reply 43 of 48, by comteck123
I'd like to ask, if I try to update windows 98 via legacy update, will it overwrite the slipstreamed files?
Reply 45 of 48, by perhenden
For people testing this out, sharing my learnings.
1 After installing the slipstream with the Vogons update set referenced here above, I got an error launching control panel for date and time.
By installing https://www.htasoft.com/w98se_post_usp4/dst_9xme.exe the error went away.
2 Via 4in1 4.43v consistently fails during setup because of "registry error", but scanregw says there is no registry error. This worked with the same hardware with the default Win98se install. (this was unrelated, it was Re: Registry error! when i instal VIA 4in1 driver)
3 The tool did not work under Linux because of Windows-style paths and case sensitivity. It didn't find the paths it was searching for, even when they were there. The tool worked under Windows.
4 Even though .NET 2.1 is no longer supported by Microsoft, you can still download and run it under Windows 11.
I realize the author recommends using other tools, but some people may find themselves in my situation where they still want to try this tool 😀
Reply 46 of 48, by theblurry99
blurry here, creator of Windows 98 Dream Edition!
(i have just made my vogons account since i never really used that website at all)
so, someone linked me this thread asking me about the mentioned Linux iso utility. i think that tool would be "HIERMA" but it seems to be taken down alongside 95D, 95D Lite and "Redtoast" (Windows 98 with 95's backport) since the fall of razorback95. sadly i don't have a copy of it since i slipstream stuff mostly by hand using INFs, putting patches into CAB files and installing them.
i know, i know it is a bit finicky and makes for a bit of a "file structure spaghetti". 98DE is a funny dev story alone since i was really young putting it together (was hitting 16 at the time of the "Revision 3" release) and was pretty clueless on how to put stuff into one package efficiently.
perhaps in the future, i could automate the process of slipstreaming updates and even complete packs of files (programs, stuff etc.) and release it as a tool, though i have been on a hiatus from the community. after all, there has been no updates since 2021 and i was thinking of bringing it all back with "Revision 4", but that will probably take some time since ... let's just say i kinda want to start from the scratch (in terms of that minimalist design).
98DE was more meant to be a fun project for me and a remaster with a focus on aesthetics while being a bit more modern 😉
hopefully i didn't go as offtop as i think and might share some light on the remaster slipstreaming side of things.
feel free to ask questions, i hope i'll respond in a reasonable time. take care.
Reply 48 of 48, by theblurry99
Nikita Lita wrote on 2024-02-24, 02:10:
bless! at least that's something archived...
