First post, by Old PC Hunter
My 286 system has no more available drive bays. Right now, it's hard drive sits on some small pieces of paper ontop of it's powersupply. Can anyone give me a better mounting solution or a hard drive pad material that's probably around my house that isn't such a fire hazard?
Set up retro boxes:
DOS:286 10 MHZ/ET4000AX1MB/270 MB HDD/4 MB RAM/Adlib/80287 XL
W98:P2 450/Radeon 7000 64 MB/23 GB HDD/SB 16 clone/384 MB RAM
XP:ATHLON X2 6000+/2 GB RAM/Radeon X1900XTX/2x120 GB SSD/1x160 GB and 1x250 GB 7.2k HDD's/ECS A740 GM-M/SB X-Fi
Reply 1 of 13, by DankEngihn
How's the drive set up? Take a picture of it. If it's got metal rails with screw holes on either side, you can just rest it on those.
Reply 2 of 13, by Old PC Hunter
The drive is set up like this, over the PSU. Also there are no drive rails.
Set up retro boxes:
Reply 3 of 13, by Warlord
what about a cd case? some velcro, a mouse pad, plastic from a dvd case, double sided tape, thin bubble wrap, mother board standoffs screwed into the bottom of the drive mounted on a piece of plastc from a cd or dvd then Velcro on. Lots of things you can do be creative. get some scissors and whatnot and cut somthing to fit there. they sell velcro at the dollar store. 🤣
dont obstruct any cooling vents.
Reply 4 of 13, by Old PC Hunter
Good idea, I think I might try a CD case. Didn't think of that.
Set up retro boxes:
Reply 5 of 13, by Doornkaat
Don't worry about that paper. It won't start burning within operating temperature of any of those devices. 😉
But maybe Velcro tape has got a couple of practical advantages over paper.
Reply 6 of 13, by derSammler
Those Conner drives can get really hot, so you should mount it in a way that allows clearance of at least 1cm on all sides.
I see lots of room inside the case to put the hard disk, but you would need to build a custom cradle to mount it anywhere there.
Reply 7 of 13, by BinaryDemon
I wouldn’t use paper in case something shorts out and creates sparks but Doornkaat is right paper won’t combust until 232C /451F. The easy way to remember this is it’s the title to Ray Bradbury’s iconic novel featuring government mind-washing and book burning - Fahrenheit 451.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 8 of 13, by PC Hoarder Patrol
This is something I've used in the past - slightly more involved but nice and secure - four of these
20.7 KiB
3M Self Adhesive Black Cable Tie Mount
placed directly below the side screwholes of the hdd, and four small zipties threaded thru the holes and mounts to secure.
Reply 9 of 13, by Jo22
Not sure if that's suitable (fire, shorts, etc), but there used to be HDD noise blockers.
They essentially were a pair of rubber bricks that could be screwed on the HDD at each side.
Depending on their height, the may also function as "feet"/stands.
Reply 11 of 13, by Caluser2000
Slim CD jewel case will do.
Reply 13 of 13, by Old PC Hunter
That's not a terrible idea, but I dont want to ruin the nice casing/sticker on my PSU.
Set up retro boxes:
