First post, by TheMobRules
I have a Seagate ST31055W "Hawk" hard drive (1.2GB, 68pin interface) that works just fine when using a PCI controller, and I want to use it in an ISA only 486. Since I already have an ISA SCSI controller (SIIG i540 "Speed Master"), I figured all I'd need to get it working is one of those 50 to 68 pin adapters. So, I bought one but so far I've been unable to get my drive detected by the controller BIOS when booting.
Here's how my SCSI is set up:
- One end of the cable is plugged into the controller, while the other end is plugged to the hard drive (via the 50 to 68 pin adapter)
- HDD SCSI ID is set to 0, with termination enabled
- Controller SCSI ID is set to 7, also with termination enabled (no external devices connected)
- I have enabled the translation option to support > 1GB drives in the controller BIOS
At boot time, the HDD spins up normally, and when the controller BIOS queries the drive I can hear it seek as the LED lights up for a couple of seconds and then "SCSI 0: no device detected" shows up and the controller proceeds with the rest of the devices (only the controller is detected, as SCSI 7), after that the boot process resumes.
A few things to consider:
- As mentioned above, the HDD works well when connected to a PCI Adaptec controller
- The SIIG ISA controller works fine with a couple of older drives with the exact same configuration (except these drives have a 50 pin interface, so no adapter needed)
Am I missing something here? Initially I thought the 50 to 68 pin might be faulty, but my continuity tests revealed nothing unusual, it's just a very simple passive adapter. Getting really frustrated with this 😠
