First post, by SquallStrife
- l33t
I have an IBM PC 330, the later Pentium model, which I wanted to deck out for use with my Streaming setup. Everything is hunky-dory except one thing:
When I install a GUS Classic 3.4, the FM on my SB Pro2 stops working, no matter what I do.
From searching, this topic comes up a lot, but doesn't seem to have a definitive answer. For some people, running ULTRINIT solves it, for others, NOT running ULTRINIT allows it to function. Indeed when I had this card in an earlier 486 build, there were intermittent issues with FM playback when the GUS had been used, which were solved by simply rebooting.
But in this system, there's just no dice. Digital sound work on the SB, and everything works nicely on the GUS, just no FM music.
Does anyone know what are the factors that cause this problem to occur? The GUS seems to respond to 0x220 and/or 0x388 writes, even without SBOS loaded. Some games (like Keen 4) detect the AdLib but silently (ha!) fail and produce no sound, others fail to detect AdLib functionality at all, and some (specifically Doom) produce a console error that AdLib is not responding.
I could understand the need to run ULTRINIT to kick the GUS into gear, and listen on the specified port instead of "everything", but in my case it doesn't seem to make a difference. The GUS is configured to 240,3,3,3,3 normally. I've tried other combinations and ports, to no avail.
It is perhaps a peculiarity of the IBM PC 330? Thoughts?
