First post, by Comos
I have made this discovery already long years ago on my system,but due to lack of time I never got any reasonable explanation,so here is a short background.
When I succesfully upgraded my Asus TX97-X rev 1.02 mosfets for a higher load to be able to run AMD K6-III, I end that a setup 6x75Mhz was the highest stable seting,that I could run here (83FSB seems not supported by the PLL in this revision).Later on I moved to K6-III+ which I clocked with the same settings,but noticed in certain tools (MPXPlay example) which are able to show CPU usage,that show approx 3% higher CPU usage.The mobo has an updated BIOS to fully support K6 and the K6 DOS optimization tools which I run @ startup remain same setting,but Im not 100% sure if K6-III+ needed something extra right now.
Any idea what this small performance drop could be made of? One fact is that the K6-III+ is represented for 100FSB only altough it does run on lower FSB aswell.
Reply 2 of 7, by Comos
Intel486dx33 wrote:
I run my K6-3+450 @ 550mhz with 2.2v.
Runs stable with no issues.
Stability is not an issue,but a performance drop between K6-III+ and K6-III when clocked @ same speed.
Reply 3 of 7, by dionb
What performance drop?
Higher CPU usage means less waiting for I/O. Might be due to more efficient cache on the III+. What happens if you actually benchmark performance per second instead of CPU usage?
Reply 4 of 7, by derSammler
Are you aware that the K6-III+ was made for mobile devices, whereas the K6-III was made for desktops? It's to be expected that power-saving features causes slighly lower performance.
Reply 6 of 7, by Comos
Yes,but the PowerNow! features set over the EPMR register are controlled over the SMM handler.To have the K6-III+ working on this board, the BIOS had to init this register upon reset into default,so under DOS it should not be active.To be really sure, I have to check that register (code some tool).
Reply 7 of 7, by Comos
Can do that,but wondering which bench tool use for that.Any example,that can give us exact numbers? (under DOS)
