First post, by gear
Hello,
i grab a Iiyama Vision Master Pro 450 that was suppose to be working.
But it don't power up. I wonder if someone have any docs/advices that could help me to fix it.
Best regards
Hello,
Best regards
Was it bought off eBay?
Does it get any sign of power whatsoever?
It might be some super basic problem, like a bad solder joint
Hello thanks to reply.
I found it on the street, a man was putting it and a desktop computer. He tell me the screen was working. But after I wired it and try to switch on, nothing happen. Normally CRT emit a sound when swith on here nothing no sound, even the light's button stay off. This button is in the feet of the screen, that why i serach for docs about this screen.
I used to have that monitor, it's sooo heavy 😁
You should be looking for the "A901HT", its actual product code, the service manual is available online:
https://www.manualslib.com/manual/1216248/Iiy … er-Pro-450.html
and here
https://elektrotanya.com/iiyama_a901ht-vm-pro … r/download.html
Be careful with it - big voltages in there. From what I've seen about monitor repair, it's usually a cracked solder joint, which with such a heavy screen can happen quite easily when it's moved.
My iiyama Vision Master 1403 (LS704UT) is showing shaking on the vertical axis. However I can't seem to find the service manual. Is this a common problem and if so what would be the required fix?
EDIT: found the service manual at https://elektrotanya.com/iiyama_vision_master … ownload.html#dl . I guess I'll check the various components, with the usual precautions.
