First post, by jammaster
Hello!
I have a voodoo 3 3000 AGP with x2 missing SMD capacitors: C16 and C17.
If a kind person could mesure them ? (I believe 0.1Nf for C17 and C16 ?)
Thk a lot.
Hello!
Thk a lot.
IIRC, all three are the same capacity, but I don't remember them being that small. You should be able to read their value without taking them off because it's printed on them.
If you have a multimeter capable of measuring capacitance and since you are obviously able to solder as you want to replace the missing ones, you could remove a similar one from that group and measure it.
That is of course if you get no better answers
the existing ones are all differents values!
taking with my ESR/cap meter.
