First post, by sonicexenia
Good evening everyone's health;
After many many attempts and tests I managed, even if not totally, to use the Xtide ite V.4 on my Olivetti M24, bios V.1.36;
I also enclose the video link.
https://www.youtube.com/watch?v=1i-UXczRTX8
As you will see, at a normal start, in the Boot phase of the CF in Xtide,
there is in the Xtide menu an exchange between C>> HDD [C] to D>> HDD [C].
Then the famous error 1h appears! and boot into A:
In this case if I try to enter the Cf, with C: it gives me a reading error, but the unit exists.
If instead, at the start, when the Xtide Menu appears, I press the D key on the keyboard
from C>> HDD [C] changes to D>> HDD [D] and everything works,
boot from Cf on Xtide lt, and CF is detected as C:
But I don't understand why the Xtide bios can't do this automatism,
without me having to press the D button.
I've tried various formatting, also done Fdisk MBR, but without solving.
