First post, by Robhalfordfan
- Oldbie
i am building a new build and still not there yet but i am still debating with myself about cases but also thinking case fans
the case i am thinking of getting is corsair 200r which room for max of 8 fans (2x front, 2x top, 2x left panel, 1x rear, 1x bottom)
but the mobo (evga 780i) only has 4x 3-pin headers and thinking of using splitter cables but i am assuming each header max power is 1 amp
thinking of these nocuta fans for the case
https://www.amazon.co.uk/gp/product/B00KF7R49 … 5RZ72I2JQ&psc=1
which says on the label DC-12V - 1.20W - 0.10A
PSU I will be using is EVGA 650 Watt GQ Gold Hybrid Modular (which has 54a on the 12v rail)
would i be safe using the fan splitters on all 4 headers with 2 fans on each and would it be enough power on the 12v rail along with GPU - GTX 580 (which it needs a min of 600w with 42a on 12v rail)
