First post, by mpe
I have a problem with my UM4981 AIO Rev 1.0 UM4981 AIO Rev 1.0 BIOS password. It 1994 486 board with Phoenix BIOS 4.03.
https://stason.org/TULARC/pc/motherboards/E/E … UM4981-AIO.html
The motherboard doesn't have any on-board battery. It only has a header for external 3V battery. Also there is no jumper for clearing password.
The board worked fine for some time, but then I changed configuration and it loaded default setup values for some reason (reported: Previous boot incomplete - Default configuration used). It doesn't boot with them (presumably as disk details are wrong).
From now on, my problem is that every-time I want enter setup it asks for 7 character password. I tried all different sorts of default passwords (PHOENIX, phoenix, CMOS, 1234567, ...). None of them seems to be working.
Once entering the password for the third time, it shows
SYSTEM DISABLED
(02F000)
It allows me to try the password again when I shorten the external battery header.
I did not set any password and was able to get to the Setup before this so this looks like a default password of some sort.
Any idea what the default password is or how to get rid of it? I thought 486-era boards should keep the password in CMOS and it should be easy to get rid of it. This one seems to be more sophisticated...
