Reply 20 of 22, by Tiido
That is case only if you don't use LBA48 patched ESDI_506.PDR. 128GB+ isn't a problem with variety of PCI RAID cards or any other thing that do not use the built in IDE driver of windows.
Reply 21 of 22, by FrankDM
derSammler wrote on 2020-01-12, 09:33:
tails wrote on 2019-10-17, 23:35:
I haven't been able to try any of the other suggestions yet but the mobo is an MSI 865PE Neo 2 and HDD is a 250GB split into in 3 partitions (111GB max) running on SATA.
Just for the record, since no one mentioned it so far: you can not use Win9x on hard disks larger than 128 GB! It doesn't matter if you make the partition smaller or not, it just won't work. Overflows will happen when Win9x addresses the sectors, randomly corrupting data. Get a smaller HDD if you want to install Win98.
Are you 100% positive on this? My 98SE machine has a 250gig drive (the 98se windows partition is 40gig) and has been running stable a long time.
Reply 22 of 22, by SirNickity
Hah -- I ran into this problem recently, too -- with Win95 OSR2. I had to skip ScanDisk, then it hung early in installation (copying the setup files or something, I think). It turned out to be because I used BeOS to partition the disk. I didn't look into what the difference actually was, but dropping the partition table and re-creating it with fdisk solved it for me as well.
