First post, by Deksor
Hello !
So yesterday I picked up a pile of motherboards, and I picked up this really nice one :
According to the internet it's a PCChips M396F, but what tickled my curiosity is that on all the motherboards pictures I've found, the chipset was renamed "PC Chips" or had a fake sticker, but mine looks untouched (unless they removed any marking and printed something new ontop of the chip, but that's not what they do usually, they prefer to put stickers). Now, was this chipset known before ? I can't find any infos on the internet except that it seems to have been used on a 286 motherboard as well ... which is also made by pcchips.
Is that the true chipset behind the scene or is it something different ?
Reply 1 of 7, by ricardo.contieri
Hi! I also own one of those m396f bur I couldn't make it work with different speeds. In your version of the board, are you able to change the speed of the processor? Are the jumpers working?
TIA
Reply 2 of 7, by jnemo2004
Hello, good morning.
I have the same motherboard but it desn't work.
All voltges are present, I see also see the reset pulse in the test card.
The processor warm normally.
Both crystals are runing, 32K and 14M.
Plate was damaged by leak of the battery (as usual) but it was repaired.
For me, probably is a BIOS issue. I do not see data transmission. It looks like dead.
I would like to load a new .bin data file in the BIOS but it is soldered to the plate. I have no enough experience to remove the BIOS chip without to damage the chip and/or the plate.
Therefore I would like to cut the chip pins and desolder one by one. In this case I will destroy the BIOS chip but I will no damage the plate.
The problem is the BIOS chip is not identify, only is writen (after to remove the sticker) M396F1. I tried to find the BIOS chip identification to buy a new or equivalent one but I was not able to find it.
Can you help me?
Thank you very much.
Regards
Reply 4 of 7, by jnemo2004
Thank you very much. Regards.
Reply 5 of 7, by jnemo2004
Hello again, I have at home the M27C256B, is it OK ?.
Thank you
Reply 7 of 7, by jnemo2004
Thankyou very much.
Sorry for to give you the thanks so late but I was busy with three motherboards socket 7, none of them works. Apparently everything was OK but they do not run. Two ZIDA and one SOYO. To solve the problem it was very easy just only to put the CR2032 due to without the battery these motherboars does not run.
